Woodworking Spray Booth
dsghdfhdf
Сообщение dsghdfhdf » 18 фев 2019, 04:23
Voltage:3 Phase 220V 60HZControl System:Schneider Components
Draft Type:Side DraftFan:Centrifugal Type
Light:Ceiling And Side Light LEDUsage:Furniture
Sidedraft Woodworking Paint Booth 6.9 Meters 3 Phase 220V 60HZ For Workshop
Features
1, Centrifugal fan for intake and extraction.
2. All panels are tongue and groove interlock structure.
3, Without heating.
4, All LED lights, energy save and more illumination.
5, Color white, blue, orange and red is optional.
6, OEM available.
Advantage:
In painting, outside fresh air comes into the fan chamber through the pre-filter system, and enters into the plenum, then filtered by ceiling filter and into the booth which brings clean, symmetrical and steady-going down airflow for spraying, and extraction from rear side by fibreglass filter filtering, finally exhausted out after carbon filter, protect the air from pollution. LED lights for woodworking painting, energy save and more illumination, high cost effective.
Specification:
ItemDetailed Specification
Inside dimension6900×3900×2650 mm (L×W×H)
Outside dimension8200×4000×3100 mm (L×W×H)
Front doorFolding door, 3 folds, 3000×2600 mm (W×H), without frame, aluminium alloy window frame, colour: white, with handles on outside.
Emergency door1 units, 800×2000mm (W×H), colour: white, aluminium alloy window frame
BasementWithout basement, exhaust from back side wall panel.
Wall panelThickness: 50mm, width: 1150mm, tongue and groove structure, 0.376mm colour steel with EPS insulation inside, colour: white.
LightCeiling Lights: 8Units×4Pcs=32Pcs×36W, side light: 8Units×4Pcs=32Pcs×36W (on the wall panel), with LED, tempered glass cover
Generator cabinetIntake from side upper, exhaust from back upper, aluminium alloy frame; machine-made panel covered, powdered and painted, filled with heat preservation material in the middle.
Intake and Exhaust systemInlet:2×3KW centrifugal fan, model: YDW4.5M1, air capacity for each fan: 10500m3/h
Outlet: 1×5.5KW centrifugal fan, model: YDW4.5S, air capacity for each fan: 15500m3/h
Heating systemWithout heating system
Purification systemPre-filter, ceiling filter, fibreglass filter, activated carbon filter
RoofGalvanized steel, ceiling filter.
Control systemSpraying, lighting switch, power supply switch, emergency stop, pressure gauge
Total power16KW (Power supply 3x220V, 60HZ)Woodworking Spray Booth
website:http://www.car-spraybooths.com/woodworking-spray-booth/
