Overview The solar street light is integrated with solar panel, led light, lithium iron phosphate battery, controller, constant current driver and luminaire housing. It is combined with multiple practical control technology including photoelectric effect, constant current control, microcontroller, human infrared induction. It can be used in the area without power gird. Product description 1.Simple design, portable, practical. 2.Powered by solar, saving energy and environmental friendly, its installation is not subject to city grid. 3.Large capacity lithium battery, lifespan about 5-8 years, twice lifespan of the traditional gel battery, lowering the battery maintenance rate of solar street lights. 4.High efficiency of usage during the lithium cycle, avoiding the low efficiency of traditional gel battery after discharge which leads to lack of energy. 5.Integrated lithium battery and controller, no complex assembly work, less wiring connection mistake, making the solar street lights installation easy and simple. 6.No additional wiring is needed, avoiding the mistake of wrong calculation in wiring length and wiring configuration. 7.Lithium battery installed on pole near the lamp, closer distance and less energy lose, ensuring high efficiency of power supply. What’s more, the hanging battery increases the difficulty for vandalism and theft than buried battery underground. Components description: Solar panel 1.Monocrystalline solar panel from 30W to 310W, efficiency of more than 18.5% 2.Polycrystalline solar panel from 30W to 270W, efficiency of more than 17.8% 3.A GRADE high efficient solar panel 4.Hydrophobic layer with higher light absorption and minimal surface dust 5.5 years warranty for solar panels; 20 years power generation capacity LED lamp 1.Intelligent Solar Controller, lithium battery 2.Over-charging/discharging Protection, Reverse-connection Protection 3.Ligh Power LED, Lifespan: >50000Hrs, White Color,130LM/W,30Lux,6500K, IP65,120 Degree Angle Material:Aluminum Solar PanelImported mono solar cell 18V 65W LED BrandBridegelux 12V 25W 2500-2700LM LED No.30 pcs Batterylithium battery 26AH Mounting Height4-7m Discharge Time5-7 rainy days Working Temperature-30℃~+60℃ CCT3000K,4000K,5000K,6000K Charge Time7 Hours Packing Type1 Set/Box Packing Dimensions1320*400*200 mm Packing Weight20KG Certification FAQ Q: If you found the light brightness is down or total off, how to handle? A: It prove the power of solar light battery is not enough to support normal lighting, so you need have 2-3 goods sunlight charged, especially in Winter season, the sunlight intensity is much below the standard sunlight (1000kw/m2), it may need more longer time to charge. Q:How many cycles full charge&discharge about your battery? A: In 50% discharging deepness, it can be cycled for 1,200 times; in floating charging and discharging status, it can be cycled for 5000~6000 times. Q. How to precede an order for products? A: 1, Let us know your requirements or application. 2, we quote according to your requirements or our suggestions. 3, Customer confirms the samples and places deposit for formal order. 4, Production arranged.Integrated Solar Street Light suppliers website:http://www.unigoostech.com/street-light/integrated-solar-street-light/ |
Сообщение dsghdfhdf » 18 фев 2019, 04:24
