CNC Router
dsghdfhdf
CNC Router
Сообщение dsghdfhdf » 18 фев 2019, 04:24
Multifunction Granite Engraving Machine for Multiple Application
● Application domain
Application areas
Apply to the stone industry, stone processing industry, art relief, advertising, decoration and decorating industry, ceramics industry.
Suitable materials
Marble, granite, jade, bluestone, Blackstone and other stone, and ceramics, glass, plexiglass, PVC board, aluminum panels, bamboo and other materials.
Granite and other hard stone can be graded to 5mm
Marble, bluestone can be engraved to 5mm at a time
● Features of machine
◆ Three axes are imported high precision linear guide , high precision, fast, wear-resistant.
◆ Double row four columns ball slider, load-bearing capacity, smooth operation
◆ Spindle can use 2.2-5kw constant power water-cooled spindle motor durable, good engraving effect, carving all kinds of stone are handy.
◆ T-one bed has good performance at strong rigidity,big strength, smooth rotation, and make long-time high-speed operation without deformation;
◆ More compatible: Compatible with Type3 / Artcam / Castmate / Proe / UG / Wentai and other CAD / CAM software;
● Technical Parameter
Product name:
X,Y,Z Working Area:
X,Y,Z Traveling Positioning Accuracy:
X,Y,Z Repositioning Accuracy:
Table Surface:
Frame:
X, Y axis transmission:
Z axis transmission:
Max. Traveling speed:
Max. Working speed:
Rail Configuration:
Spindle Power:
Spindle rotationg Speed:
Drive and Motors:
Working Voltage:
Operating System:
Command Language:
Software Compatibility:
Packing:
N.W.:cnc Marble Cutting Machine
1300x2500x250mm
±0.05mm
±0.05mm
Aluminum T-slot Table
Square pipe Welded Structure
Rack and Pinion gear
Ball Screw
25000mm/min
15000mm/min
20 square rail
Water-cooling 5.5kw(Opitioinal 3.0 ,4.5 ,7.5kw) spindle:
0-24000RPM
Stepper System (Opitional: Servo motors)
AC380V,50Hz,3PH
NC studio system(Option: DSP)
G code, u00, mmg, PLT, HPG
Type3,Wentai,Artcut
Wooden case
1800KG
● Detail determines quality
● Sample pictures show
● Packing and shipping
● CE/FDA
● Q$A
1. This is the first time I use this kind of machine, is it easy to operate.
There are English manual or guide video that show how to use machine.
2. If machine has any problem after I ordered it, how could I do?
Free parts send you in machine warranty period if machine have any problem.
Free after-sales service life for machine, please feel free contact usif your machine have any problem. we will give you 24 hours service though phone and Skype.
3. Minimum order quantity
Our MOQ is 1 sets machine. We could send machine to your country port or your factory directly, please tell us your port name or your detailed address. There will be best shipping freight and machine price send to you.
Contact us
Emma
Email: emma@unistarcnc.com
Skype: unistarcnc01CNC Router
website:http://www.unistarcnclaser.com/cnc-router/
