UPVC Roofing Eco friendly building materials Plastic Roofing Sheets SMARTROOF Eco friendly building materials Plastic Roofing Sheets, is made from Green Synthetic Resin. It is not only omre stable material, but also better feature material. Meanwhile, with ASA coating, makes it better in aging protection. So please check the below information of this product. Specification: Eco friendly building materials Plastic Roofing Sheets Brand SMARTROOF Main Material Synthetic Resin / PVC Coating Material Anti Aging ASA Total Width 1050 MM Real Width 960 MM Length Customized by times of pitches Thickness 2.5MM / 3.0MM Color Brick Red / Purplish Red / As Order Guarantee 20 Years Profile Detail: 1050 Spanish Roof Style Total Width 1050 MM Real Width 960MM Wave Height 30 MM Wave distance 160 MM Pitch Distance 218 MM Advantages: Excellent Heat Insulation Better Corrosive Resistance Longer Lifespan Lasting Color Light Weight Easy Installation Compared With Traditional Metal Roof: Plastic Roofing Sheets Color Metal Roof Sheet Heat Insulation √ × Corrosive Resistance √ × Chemical Resistance √ × High Strength √ √ Water Proof √ √ Self Cleaning √ × Sound Insulation √ × Color Lasting √ × Project Showcase: SMARTROOF Not Just Roofing-But Roofing Solutions UPVC Plastic Roofing Sheet Free Sample website:http://www.smartroofasia.com/plastic-roofin/upvc-plastic-roofing-sheet/ |
Сообщение dsghdfhdfs » 19 фев 2019, 05:32
