Sliding barn door kit Specification Warranty: Five Years; Color: Black; Main Material: Metal&Steel; Heavy Duty Construction Durable; Load-bearing: Maximum 220lbs/(100kg) Each Door; Fit Door Panel Thickness: about 1.57"-1.77"/(4cm-4.5cm); Rail width: 1.57" (4cm); Rail thickness: 0.24" (6mm); Roller wheel diameter: 2.75" (7cm); The clearance from the top of the door to the ceiling needs minimum about: 5.9"(15cm); Only sell hardware, No door included! Comes with all the hardware needed for one door. Features: Enhance Room - Perfect for a study, dining room area or an elegant transition between spaces, barn doors enhance and unify your space with light and beauty Adding Style - Solid wood barn unfinished Pine door creates a rustic style Easy Installation - Doors are predrilled for easy installation to track hardware, handle and floor guides require additional drilling. Heavy Duty Construction - Thick construction resists warping and adds added dimension of durability to your home Door Opening - Fits single door openings between 42 in. W and 84 in. H Space Saving Solution - Barn doors are also an excellent space saving solution versus a tradition swing door while adding character and a unique charm to any room Customization - Door is made of unfinished pine, so you can paint or stain it for perfect customization FAQ Q: Which stainless steel barn door hardware is hot-saling products? A: Model Top mount and 96" Track Q: How long has Moran Hardware in Business? A: Moran Hardware has been in business for approximately 10 years. Q: Is there a key contact at Moran Hardware? A: You can contact us at 0086-573-83875909. Skype: niuniuheyanyan1 Wechat: 86-15824360745 Q: What is your main products? A: Our main products are sliding barn door hardware,barn door pulls, lever door handle. Q: Can you please ship the goods to our warehouse? A: Yes, we can.Glass Steel Door Hardware wholesale website:http://www.jiaxingmoranhardware.com/sliding-door-hardware/glass-steel-door-hardware/ |
Сообщение h83tqx » 26 фев 2019, 05:15
