| Wholeale Biodegradable Straws Paper Straw Making Machine This Machine is suitable for producing different sizes of paper straws and very small paper tubes. [1] It adopted with PLC controller; main motor is equipped with variable frequency speed regulation; touch screen man-machine interface. Easy for parameters setting & operating. [2] Cutting section adopted with numerical multi-blades cutting system. Servo synchronous tracking cutting system makes it higher precision and multi-blades cutting makes it higher efficiency. [3] Machine body and main spare parts made by stainless steel instead of painting. Ensure the hygiene and environmental protection of the products. Technical Parameter Technical ParameterControl System Paper Layer3 layersMotor3.0kw Inner Diameter5-12mmPLCPanel Master Wall Thickness0.5-1mmOperating PanelPanel Master Winding Speed20-40 meters/minInverter3.7kw Schneider Winding NoseTwo noses single beltElectric ComponentsSchneider Cutting SystemNumerical Multi-blades (standard 5 pcs)Servo MotorSchneider Synchronism tracking cutting systemServo motor synchronism trackingPneumatic ComponentsJingwei BearingHaerbin Gluing WaySingle/Double sidesScrew Rod / SliderShangyin Working Air Pressure0.6 MpaConfiguration Operator1-2 personPaper Reel Stand3 Layers Power Supply380V/3Phase/50HzGluing Unit3 Layers Measurement & WeightBelt5 Pieces Measurement3500*1500*1200mmMandrel Shaft2 Pieces Working Space7000*5000mmExtra blades5 Pieces Weight1300kgsUseful Tool1 Set Multi-knives Inline Cutting System Aluminum-Profile Paper Reel Stand Aluminum-Profile Glue Unit Finished Products Paper Drinking Straws Dear friends, to make paper straws, I sincerely recommend four machines for you: NO.1 Paper Slitter Rewinder Machine Cut rolls into smaller rolls. NO.2 paper straw making machine NO.3 paper straw flexo printing machine NO.4 Paper Straw Packing Machine Packaged by plastic or paper. Packaging & ShippingChina Paper Straw Making Machine website:http://www.jingfengmachine.com/paper-straw-making-machine/ |
Сообщение ffffyyyq » 18 апр 2019, 08:12
