Quick Details
Place of OriginChina
Brand NameKingfair
Model NumberVIP card
MaterialPVC
Size85.5*54mm or customized
Thickness0.76mm/0.84mm/Customized
SurfaceMatte Glossy Frosted
PrintingCMYK Offset Printing
MOQ500pcs
Craftoptional
Supply Ability
Supply Ability:1000000 Piece/Pieces per Month
Packaging & Delivery
Packaging Details:200 pcs/box, 20boxes/carton
Port:Shanghai or as demanded
RFID card is encapsulated in PVC card with composing of IC chip and induction antenna. It combines the technology of RFID card and IC card to solve the problem of passive and contactless. Those cards work by contactless read-write technology, in addition to CPU, logic unit and storage unit, and RF transceiver circuit.
Material:PVC/PET/PETG/ABS/Paper
Frequency:Low-Frequency 125KHz,High-Frequency 13.56MHz,Ultra-High Frequency 433MHz,Ultra-High Frequency 915MHz
Working Temperature:-10℃~50℃
Chip: EM4200,TK4100,T5577, Hitag, EM4305, MF/S50,S70,I-CODE,U-CODE HSL,U-CODE GEN 2 and etc.
Printer:Evolis, Fargo, Magi card, Zebra, Data Card, etc.
Card surface: Matte/Glossy/Frosted Finish or customized
RFID cards could be widely using for bank, traffic, super market, club, tickets, parking, library management, access control, school student management,petrol station and so on.
High-practicality
There are no chips falling off, static breakdown, bending damage and so on because of no chips on the card surface. The card can be conveniently operated within the effective range which improves the reading speed.
Automatic identification
RFID card can prevent data interference between different cards, and the reader can handle multiple cards at the same time.
Wide range of Applications
RFID Card can be used in different systems with one card, users are allowed to set different passwords and access conditions according to different applications.
Well-encryption
Two ways authentication mechanism, there are operation passwords and access conditions in each sector.
Low Frequency 125KHz
RFID ICIC ManufacturerRF ProtocolMemory
TK4100EM MICROELECTRONIC/64bit unique R/O
EM4200EM MICROELECTRONIC/128 Byte R/W
EM4305EM MICROELECTRONIC/1K Byte EEPROM
T5577Atmel/330 bit R/W
NXP/2018 bit EEPROM
NXP/256 bit R/W
S SeriesNXP/256-2048 bit EEPROM
HIDHID Global/256 bit R/W
High Frequency
13.56MHz RFID ICIC ManufacturerRF ProtocolMemory
MF S50 1K(NXP) NXP ISO 14443A 1K-Byte EEPROM
ISSI 4439(MF 1K compatible)ISSI ISO 14443A8K-Byte EEPROM
FM11RF08(MF 1K compatible)Shanghai Fudan(China) ISO 14443A 1K-Byte EEPROM
MF S70 4K(NXP)NXP ISO 14443A 4K-Byte EEPROM
MF Ultralight(NXP) NXP ISO 14443A 512-bit EEPROM
MF DESFire NXP ISO 14443A 4K-Byte EEPROM
MF Plus1KNXPISO 14443A1K-Byte EEPROM
SLI NXP ISO 15693 1K-Byte EEPROM
Tag-it HF Ti2048 Texas Instrument (TI) ISO 15693 2K-Byte EEPROM
Legic MIM256LegicLegic RF Standard256-Byte EEPROM
Ultra High Frequency
868-915MHz RFID ICIC ManufacturerRF ProtocolMemory
H3/H4 AlienEPC Class1 Gen2.
ISO 18000-6C240bit / 512bit EPC + TID
Monza 3 /Monza 4/ Monza5 ImpinjEPC Class1 Gen2.
ISO 18000-6CEPC memory allocation: 96bit
Customized Loyalty Card
website:http://www.kfrfid.com/loyalty-card/
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 6 гостей
