| LINKUN® is a company which has been dedicated to manufacturing, distributing, processing and exporting SEAMLESS, ERW/HFW, LSAW/JCOE Steel Pipes & Tubes for more than 20 years, our products originate from our domestic famous state-owned and joint venture mills like BAOSTEEL, TPCO, VALIN STEEL, BAOTOU STEEL, XINYEGANG STEEL, ANGANG STEEL, SHASTEEL, TIANDA GROUP, etc. We also distrubute special steel from JFE Steel, NSSMC, THYSSENKRUPP, OUTOKUMPU, etc. We have been dedicated to professional production, taking quality and customer satisfaction as our highest goals. In continually freely adjusting production and sales strategy, we have responded to rapid changes in market requirements. All our products are manufactured by latest manufacturing techniques with machines and equipment which fitted highest technology, in order to provide the manufacturing of products in full conformity with international standards with high quality materials in production in line with its carefully set policies for sustainable quality. Our main products are Line Pipe, OCTG, Boiler tube, Heat-exchanger Tube, Condenser Tube, Super-heater Tube, Hydraulic Honed Tube, Mechanical Tubing, Hollow Structural Section, Pipe Fittings and Pipe flanges according to ASTM, ANSI, ASME, API, DIN, JIS standards We also can produce 3LPE, 3LPP, FBE, Liquid Epoxy, Zinc-rich Epoxy Primer coated Steel Pipe according to DIN 30670, DIN 30678, CSA Z245.20, EN 10339, ISO 21809-1, AWWA C210, AWWA C213 international standards. Our Pipe and Tube Manufacturing Process: 1. Seamless: Hot-Rolled Outside Diameter: 10.3-1020mm;Wall Thickness: 1.73-100mm Cold-Drawn:Outside Diameter: 6-220mm;Wall Thickness: 1-20mm 2. Welded: UOE/JCOE Longitudinal Welded (LSAW):Outside Diameter: 406.4-1422mm;Wall Thickness: 6.4-44.5mm High Frequency Electric Resistance Welded (HFW/ERW) & Electric Fusion Welded (EFW):Outside Diameter: 21.3-508mm;Wall Thickness: 3.2-15.9mm Inspection & Approval Certificates: Mill Test Certificate, C/W Certificate (Calibration Works Certificate) EN 10204 3.1, DIN 50049 3.1, ISO 10474 3.1,NACE MR-0103/NACE MR-0175/ISO 15156, PED-97/23/EC, AD-2000-WO, with 3.2 certificate duly Certified &Approved by LRS, GL, BV, DNV, ABS, SGS, TUV, RINA, IRS, NORSOK, etc. Our Main Customers: Service: We provide product customization service such as: Shot Blasting, Precision Pipe Cutting, Cut and Roll Grooving,Custom pipe fabrication, Pipes Threading, Pipe Beveling, Coating.They are also approved by Third Party Inspection Agencies like DNV, BV, SGS, Moody, TUV, ABS,LR, GL, PED,RINA, KR, NKK, AIB-VINEOTTE, CEIL, VELOSI, CCSI, etc. Our Mission: We endeavor to deliver the highest quality products and value-added services to support our clients' business. We take care of everything so our clients can remain focused on their business. We help our clients make more money by bringing companies together and creating win-win partnerships. We are an insider in the pipe and tube manufacturing industry and therefore are in a position that allows our clients to have an insider working for them. We even purchase the steel so that our clients do not tie up capital until they receive their order and are completely satisfied with their products. We understand the system and put it to work to the advantage of our clients. Welcome to inquire us prices and visit our company and facilities!China C45 cold drawn steel tube suppliers website:http://www.lksteelpipe.com/ |
Сообщение yyghgh » 15 июл 2019, 05:22
