low price PWM Solar Charge Controller
(Здесь собраны новостройки из ТАО)
astao47
Сообщение astao47 » 25 июл 2019, 12:14
Quick Detail
Rated Voltage: 240V/360V/384V
Maximum Current: 150A/200A/250A/300A
Display: 3'' LCD Screen
Connection port: Waterproof
Accessories: Charger Adapter
Supply Ability: 8000 Piece/Pieces per Month solar system PWM battery charger controller
Packaging & Delivery
Packaging Details
Carton or wooden for Big charging current 150A/200A/250A/300A solar system PWM battery charger controller
Port: Shanghai or Yangzhou
Lead Time: Shipped in 3 days after payment
Product Characteristic: The solar charge controller adopts industrial-grade chips to ensure the stable feature of controller
Excellent EMC design
High efficient PWM charging technology which has three charging stages (buck charging stage, equalize charging stage and float charging stage), and improves battery storage efficiency and charging efficiency.
Advanced battery activation technology which increases battery lifetime 30% at least and improves the system performance
The 30A to 300A solar charge controller adopts imported IGBT power module or MOSFET as electronic switch which can improve the stable performance of controller. There aren’t any mechanical switches in the system
LCD will display the system status and working parameters
Parameters setting flexibly
Users can parallel connect lots of the controller is a system
Fully enclosed duct design and high speed fan for cooling making the controller working in a variety of harsh environments
DC output function (Optional)
Standard Modbus protocol for RS-485 communication to extend the communication distance (Optional)
The solar charge controller will alarm when the system status is abnormal
New SOC method displays battery power accurately
With power generation statistics function to facilitate the view of power generation of daily, month and total.
There is temperature compensation function which will compensate the temperature according to different battery type.
The solar charge controller adopts graphical dot-matrix LCD and 4 buttons as HMI for full menu and easy operation RTC time function.
Parameters of 150A to 300A solar charger controller
System voltage BZC-: 24V, 48V, 96V, 192V, 240V, 360V, 480V, 540V, 600V
Max. VOC of PV arrays: 100V, 100V, 200V, 350V, 450V, 700V, 950V, 1000V, 1000V
Rated charging current: 150A, 200A, 250A, 300A, 350A, 400A
Equalize charging point: 28.8V, 57.6V, 115.2V, 230.4V, 288V, 432V, 576V, 648V, 720V
Equalize charging recovery point: 26.4V, 52.8V, 105.6V, 211.2V, 264V, 396V, 528V, 594V, 660V
Equalize charging time: 120 minutes (default setting)
Float charging point: 27.6V, 55.2V, 110.4V, 220.8V, 276V, 414V, 552V, 621V, 590V
Over voltage point: 32V, 64V, 128V, 256V, 320V, 480V, 640V, 720V, 800V
Over voltage recovery point: 30V, 60V, 120V, 240V, 300V, 450V, 600V, 675V, 750V
Stand-by consumption: <0.5W
Display: 3'' LCD
Display language: English
Terminal type: TC series barrier terminal
Elevation: <4000 meter, should reduce power if the elevation high than 4000 meter
Humidity: 0~98%, non-condensing
Protection level: IP32
Noise: <30dBA
Cooling method: High speed fan + heat sink
Environment temperature: -25°c~55°c
Dimension: 900*520*500
Net Weight: 75KG
What is PWM charge controller:
PWM (Pulse-Width Modulation) is the most effective means to achieve constant voltage battery charging by switching the solar system controller's power devices.
When in PWM regulation, the current from the solar array tapers according to the battery's condition and recharging needs.low price PWM Solar Charge Controller
website:http://www.fsypvenergy.com/solar-controller/pwm-solar-charge-controller/
Вернуться в «ТАО - Троицкий административный округ»
