P16 DIP Outdoor Perimeter Led Screen
1.Main Features And Functions
LEDventure’s perimeter display solutions create flexible, cost-effective advertising mediums and give you the ultimate sports experience - before, during and after the game. As for sponsors and vendors, they will love your LEDventure display's attention-grabbing power for promotion for future events, merchandise and concession sales!
1.1 The Option for UEFA
It totally meets UEFA stadium standard requirement, TUV-EMC certificated, widely used in different sport events.
1.2 High Quality Design, Best Option For Outdoor Application
Robust and shockproof, Modular waterproof design, IP65 all weather available, which makes outdoor use reliable, saving operational cost.
1.3 HD Perfect Performance, The First Option For Advertising
High resolution displays delicate and vivid pictures. HD camera can shoot every wonderful scene.
1.4 Independent Ground Support, High Stability
Flexible angle between 75° and 90° makes sure a best viewing angle. Panels are 2cm above ground, effective water proof.
1.5 Player Protection Design
Special soft screen mask and protector design, even by external attack, it can protect the player's safety.
1.6 Quick Installation
Rational dimension plus quick connection button between cabinets make it quite easy for workers to install.
1.7.Dual Backup Data System,More Reliable
Adopt dual backup design of data system, when 1 data line breaks down, the other data line will be automatically started to ensure the stable working of display screen, reliable and worry-free.
2. Main Technical Specifications
PARAMETERS DESCRIPTION
Brightness≥8500 Nits
Viewing angleH: 120°; V: 60°
Panel weight50 kg
Panel sizeW1280mm x H960mm x D100mm
Panel materialAluminum
Ingress protectionFront/Rear: IP65/IP54
Operating Temperature/Humidity-20℃ - +50℃/ 10-90%RH
Storage Temperature/Humidity-40℃ - +60℃/ 10-90%RH
Pixel configuration1R1G1B
Pixel Pitch16mm
Pixels per panel80x60Dots
Physical density3906 pixels / m 2
Recommended viewing distance16M
Color4.4 trillion
Gray scale65536 levels per color
Brightness control256 levels of each color(manually),8 levels of each color(automatically)
Contrast ratio1000:1
Processing depth16bits
Video frame rate1920Hz
Input voltage110-220VAC+-10%
Input power frequency50-60Hz
Input power <max>150watts
Input power <typical>500watts
Life Time≥100,000 Hours
LED WavelengthR:620-625nm G:520-523nm B:470-473nm
Driving Method1/1 scan
LED EncapsulationDIP346
Input signalRF,S-VIDEO,RGBHV,YUV,YC & COMPOSITION, etc
CertificationsCCC,CE,FCC,ETL,IP65,EMC
3. Application
Sport stadium perimeter led screen is a series which use for sport stadium for Brand marketing during sport events, such as World cup etc. the advertising is simple with companies LOGOS, such as NIKE, COCACALA,SONY etc, this series led screen require very strictly in led screen cabinet design, soft mask to protect led ,also security glue, our sport stadium led screen is specific designly with standing legs, viewing adjustable parts, both available standing and angle-standing for target audiences.
4.Our Installation Reference
5. Our Services
1. Various dimensions available for ur different needs.
2. We provide OEM and ODM services. We can customize the size, shape, thickness, printing of the packaging upon request.
3. making samples for approval
4. for your any inquiries or recommends we will try our best to give you our reply within 24hours.
5.Local service points for local supports,technical supports and repairing etc.
6. FAQ
1. How about the warranty ?
2-5 years warranty.
2. What is your terms of delivery?
We accept EXW, FOB, CFR, CIF, DDU, etc. You can choose the one which is the most convenient or
cost effective for you.
3. What kind of display we provide?
We have indoor/outdoor/mobile LED /rental LED display /LED stage/LED Dance Floor/Irregular LED display/stadium LED Display for you choose.
4. What about the lead time for order?
Always: 7-20 days, as your order quantity, sometimes we have stock, can delivery within 7 days
5. What is LED display of the IP protection grade?
IP protection grade is composed of two digital, the first digital representation from the dust of lamps and lanterns,the level of the external things out, the second digit said moisture proof.
7.Contact Us
To receive a catalogue, pricing information and a sample of a sign for your needs, just leave an Inquiry to get a quick quotation by those contact ways.
Shenzhen LEDventure Co.,Ltd
Add: LEDventure Building , Lebao Industrial Park, Fengxin Road, Guangming New District, Shenzhen, China
Contact us: Peter Liao
Tel: +86-0755-23353959
Fax: +86-0755-23353959
Mob/WhatsApp/Wechat: +86-18902466151
E-mail: sales@ledventure.cnwholesale Outdoor Stadium LED Display
website:http://www.ledperimeter.com/perimeter-led-display/outdoor-stadium-led-display/
wszj222333
Вернуться в «Форум жителей ЖК - «Квартал 38А»»
