Innokin JEM AIO Flavor Vape Pen 13W 1000mAh
Сообщение sihang » 28 авг 2019, 05:47
Зарегистрируйтесь, чтобы увидеть ссылку! Vape Pen 13W 1000mAh
Description
The Innokin JEM AIO Vape Pen, which was designed for the mouth to lung vaping lovers. with the ultra-slim size, compact structure and diameter is 16mm. built-in 1000mah battery and the constant output power is 13W, can charge the built-in battery via the micro USB port and the tri-color LED indicator light will show the current battery charge level clearly. the full safety protections will ensure the vape safe and reliable. there is only one button design, pressing the button 5times to power on and press the button to enjoy the vaping. the JEM Tank with 2ml e-juice capacity, with convenient top e-juice refill design, there are 1.6ohm kanthal coil and 2.0ohm ceramic coil available. will deliver the full intense flavors with every puff.
Color:white, blue, black, stainless steel, powder, universe
[img=744x593]https://worldvaporstore.com/wp-content/uploads/2019/08/2-11.jpg[/img]
[th]Main features[/th]
[th]Package Contents[/th]
Convenient Top E-Juice Refill Design
Built-In 1000mAh Battery
Capacity:2ML E-Juice
Constant Output Power 13W
Working Voltage: 3.7V
Max Output Voltage: 5.5V
Max Output Current: 5.0A
Resistance Range: 0.6-3.5ohm
E-Juice Window
Tri-Color LED Shows The Battery Charge Level
Micro USB For Charging
15S Auto Cut-Off Protection
Over-Discharge Protection
Over-Charge Protection
Short Circuit Protection
Over-Heat Protection
High-Resistance Protection
Kanthal 1.6ohm Coil, 10-13.5W
Ceramic 2.0ohm Coil, 10-13W
1*JEM Vape Pen
1*1.6ohm Kanthal Coil
1*2.0ohm Ceramic Coil
1*Micro USB Cable
1*Spare Parts
