veek Airo Pod System Kit 360mAh
Сообщение sihang » 28 авг 2019, 06:01
Descriptions:
Зарегистрируйтесь, чтобы увидеть ссылку! Kit by VEIIK, The first impression when i saw this kit is luxurious. With Airo Kit, you can easily stand out from all pods in the vape market. Premiering with exquisite PU sticked panels on the front and back. 2ml refillable cartridge and 360mAh built-in battery. It is a super portable device with the height of 100.5mm, width of 25.5mm and thickness of 12.5mm. Special bottom light indicator tells you the real battery life.
Specifications:
Size: 25.5mm x 12.5mm x 100.5mm
Capacity: 2ml
Material: Zinc Alloy+PU
Battery: 360mAh
Resistance: 1.2ohm
Charging Currant:1A
Color: Brown, Black, Red, Blue, Rainbow & Black
Package Incudes:
1 x Airo Battery
2 x Airo Cartridges
1 x USB Cable
1 x User Manual
