Augvape Merlin Nano MTL RTA
Сообщение sihang » 02 сен 2019, 05:47
Зарегистрируйтесь, чтобы увидеть ссылку! MTL RTA
Description
The AUGVAPE Merlin Nano RTA is featured with bottom refilling system, 2ml e-liquid capacity and an extra 3.5ml PCTG bubble glass to serve your different vaping frequency. The Merlin Nano has two posts and single coil build deck. Two top mounted screws and Peek heat Insulation platform will make it easy to build coil. The peek chamber makes heating more effectively. Three different air flow inserts and the hidden airflow design will help enhance the flavor of e-juice. Come and get one great AUGVAPE Merlin Nano RTA for your wonderful vaping.
Color:Matte Silver,Stainless Steel,Matte Black,Black,Gold,Rainbow,Gun Metal
[img=268x285]https://worldvaporstore.com/wp-content/uploads/2019/08/1-2.png[/img]
AUGVAPE MERLIN NANO 18MM MTL RTA
Augvape presents the Merlin Nano MTL RTA, a 18mm rebuildable tank atomizer with 2ml Зарегистрируйтесь, чтобы увидеть ссылку! capacity and a smooth mouth to lung draw. The Merlin Nano RTA's build deck features a dual post single terminal build deck and a non-adjustable airflow open located at the base of the RTA which siphons air up through the bottom of the build deck giving the perfect MTL draw every time. Looking closer, this rebuildable tank atomizer measures at 18mm in base diameter, accommodating most, if not a high percentage of vape mods in the market and with two finishes to choose from the Merlin Nano can fit nicely on various mods. For added user customization, an added 3.5ml acrylic tank and 22mm beauty ring is included within the package.
Internally, the Merlin Nano RTA features the a dual post single terminal build deck that features an adjustable airflow control system. The airflow can be manipulated via three interchangeable airhole inserts. Each insert measures 7mm by 4mm and has from 1mm to dual 1mm air holes. The terminal measures in at 4mm by 5mm and can accommodate a single coil build configuration. As an added feature, Philip screws are located at the top of each terminal for hassle free coil installations. A unique PEEK chamber encompasses the entire build deck to reduce heat effectively and keep flavor on point.
Overall the Merlin Nano MTL RTA by Augvape is a solid example of a well executed mouth to lung RTA, and a must have for builders and flavor connoisseurs alike.
Product Specifications
  • 18mm Merlin Nano
    [ul]
    [li]2ml Capacity
    [ul]
    [li]3.5ml Bubble Tank
[/li]
  • 22mm Beauty Ring
  • Stainless Steel Construction
  • MTL
  • [/ul]
    [/li]
  • Adjustable Airflow Inserts
      [li]1mm Airflow Hole
    • 1.2mm Airflow Hole
    • 1mm Dual Airflow Holes
    [/li]
  • Gold plated 510
  • [/ul]
    Product Includes
