Silicone Roller
fangfangfang2
Silicone Roller
Сообщение fangfangfang2 » 03 сен 2019, 10:53
Silicone rubber roller can easily match with different surface molding plastic parts, and high heat resistance, easy polishing other, ensuring smooth application of heat transfer and film bronzing.The company has exclusive special formula, strict production process, with high pressure injection imports of machinery and equipment.
1) high and low temperature resistance. Silicon rubber roller is a heat-resistant rubber roller. In all kinds of rubber, it has the most wide working temperature range (-100 to 350).
2) excellent resistance to ozone aging, light aging resistance and weathering. Vulcanized silicone rubber in the free state in outdoor exposure for several years, no significant change in performance.
3) excellent electrical insulation properties. Electrical insulating properties of vulcanized silicone rubber roller after little change in water or at elevated temperatures in damp, silica, formed after combustion is an insulator, which can ensure the electric equipment to work, until the maintenance.
4) silicone rubber roller and oil resistance, radiation resistance, flame resistance and other properties.
5) the pressure of high degree, deformation recovery.
6) made of exclusive special curing process, long life expectancy.
7) elastic first-class, good toughness.
8) fast heat conduction, heat conduction performance is excellent.
9) good wear resistance.
FAQ:
1.When can I get the quotation?
We usually quoted within 24 hours after receiving your inquiry. If you are very urgent to get the price, please call us or tell us in your email, so that we can regard your inquiry priority.
2.How should I place the order?
Please show us the drawings of your rubber roller, tell me The Rubber thickness, the effective roller face length and the total length, and other details information, then we will provide you drawing for confirmation.
3.What's your MOQ basis?
1 piece or 1 set, it depends on your actual requirement.
4.What about the lead time for production?
Honestly, it depends on the order quantity and the type of our products.
5.What is the term of delivery?
We can arrange with EXW, FOB, CIF…etc. You can choose the most convenient one or cost-effective way.Silicone Roller
website:http://www.china-rubberroller.com/rubber-roller/silicone-roller/
