Product Description Cement floor is a kind of high density structural flooring which is made of high-grade silicate cement,silica sand,imported native wood pulp and other organic and inorganic materials. and adpopting the advanced production process like blending,molding, pressurization,high-temperature and high compress steam curing. It is special for flooring an loft. Product Parameter Namecement floor Standard sizes1220×2440mm,thickness from 18-25mm Edge Type Density(g/cm3)1.6 Wet exoansion%0.146 Water absorption rate %≤26 Water impermeabilityAfter 24 hours of water immersion, no water droplets appear on the bottom surface Freezing resistance25 cycles of freeze-thaw, no delamination, etc. Uniform Loading%12500N/M2 Concentrated load %2950N Product Advantages Product ApplicationFlooring website:http://www.wall-panel.com/flooring/ |
Flooring
Flooring
Сообщение fangfangfang2 » 03 сен 2019, 10:56
