ATVS Xipod Starter Kit 650mah
Сообщение sihang » 04 сен 2019, 09:56
Зарегистрируйтесь, чтобы увидеть ссылку! Starter Kit 650mah
Made from zinc alloy and PCTG, ATVS Xipod Starter Kit comes with lightweight in a tiny size, and it is durable. ATVS Xipod utilizes ceramic coil, has stable heat conduction of ceramic coil which brings purer taste. Works with built-in 650mAh lithium battery, Xipod kit has long standby time for your daily vaping.
Color: black, blue, brown, pink
[img=341x250]https://worldvaporstore.com/wp-content/uploads/2019/07/1-92.png[/img]
[th]Main features[/th]
[th]Package Contents[/th]
Brand:ATVS
Material: Material Zinc Alloy & PCTG
Battery:650mAh
Capacity: 2ml
Charging Cable:USB Port
Dimension 88* 31* 14mm
Refill Bottom Filling
Coil Ceramic coil
Resistance 1.0ohm
Temperature range 200℃ 240℃ 270℃
Charging Time 90mins
Connection Magnetic Connection
1* Xi pod battery
1* Xi pod
1* USB Cable
1* User Manual
1* Warranty card
