NS Vaporizer Pen Starter Kit – Vandy Vape
Сообщение sihang » 04 сен 2019, 10:05
Зарегистрируйтесь, чтобы увидеть ссылку! Starter Kit – Vandy Vape
[img=304x358]https://worldvaporstore.com/wp-content/uploads/2019/07/33.png[/img]
[th]Main features[/th]
[th]Product Features[/th]
[th]Package Contains[/th]
Brand : Vandy Vape
Battery: Built-in 650mAh battery
Capacity:1.5ml of e liquid
Charging Cable:USB
Magnetic cap
Simple E-liquid filling:
Rotate the top cap
Open the top cap
Fill the E-liquid
NS Coils:
Resistance: 1.2ohm
Best adapted power: 9W
LED button mode switching:
Click fire button 3 times
Output voltage cyclically switch among 3 level
LED flash 3 times is current voltage:
Level 1: 3.4V, constant voltage output less then 3.4V, bypass mode, red light
Level 2: 3.6V, constant voltage output less than 3.6V, bypass mode, green light
Level 3: 3.8V, constant voltage output less than 3.8V, bypass mode, white light
Spring-loaded firing button
14mm overall diameter
1 * NS Vaporizer Pen Starter Kit
2 * Coil
1 * USB Cable
1 * English Using Manual
1 * Accessory Bag
