| Dibutyltin diacetate(DBTA) CAS No.: 1067-33-0 MF: C12H24O4Sn MW: 351.0 Physical property Melting point: 10℃ Density: 1.32±0.005(20℃) Boiling point: 140-144℃/10mmHg Refractive index: 1.471 n20/D(lit.) Specifications Appearance: Colorless to pale yellow oil liquid Tin Content: 32.0-33.0% Chroma(Pt-Co): ≤100﹟ Characters Catalytic speed is faster than Dibutyltin Dilaurate Applications 1.Dibutyltin diacetate is mainly used as Curing Catalyst for room temperature silicone rubber; especially suitable for deacetic type RTV silicone rubber; 2.To reduce its acetic acid smell, can use it with Dibutyltin Dilaurate, usually by Dibutyltin diacetate:Dibutyltin dilaurate is 1:9 or 2:8; 3.Dibutyltin diacetate can be used as polyurethane coating catalyst. Storage 1. This product shall be immediately covered tight after use, it is easily hydrolyszed when exposed to air and separate out solid at bottle mouth; 2. Kept in cool dry places, after use, lid airtightly timely, reducing contact with air; 3. Should avoid touching the skin, mucous membrane, if touched, wash immediately with plenty of water. Packing 25KG/ Plasitc Drum 200KG/iron drumTin Catalyst suppliers website:http://www.pu-haotaichem.com/polyurethane-catalyst/tin-catalyst/ |
Сообщение blfn888 » 05 сен 2019, 09:26
