Advken OWL Mesh Sub-Ohm Tank
Сообщение sihang » 06 сен 2019, 11:06
Зарегистрируйтесь, чтобы увидеть ссылку! Mesh Зарегистрируйтесь, чтобы увидеть ссылку!
The ADVKEN Owl Mesh Sub-Ohm Tank is a 24mm diameter mesh atomizer that can use a multitude of coil heads ranging from the SMOK TFV8 Baby Beast to the Vaporesso NRG Replacement Coil Head. Having two types of tank selection allows users to choose from either a 4ml bubble glass tank section or a standard 3ml straight glass tank section. Filling the Owl is simplified with a single fill port paired with a push to open fill port. To prevent leakage from juice or condensation the Owl features a top airflow configuration, providing two airflow slots that are completely adjustable.
The Advken Owl Mesh Sub-Ohm Tank is an innovative tank, utilizing a superior stainless steel chassis construction, sliding top refill and airflow control system, and accepts coils from the Advken Mesh Coil Line. The Owl Mesh Sub-Ohm Tank is formed from superior stainless steel chassis construction and features pyrex glass reinforcement to protect the 3mL straight or 4mL bubble glass options. To fill the respective glass tanks, the Owl is possesses a sliding top refill system, revealing a single bean shaped fill port. The top airflow control ring is dual slotted and knurled for easy manipulation to select the proper airflow. Furthermore, the Advken Owl Mesh Sub-Ohm tank utilizes coils from their mesh coil line, accepting a 0.16ohm or 0.2ohm mesh coil. These coils maintain a better contact with the juice laden cotton, evenly heating up for a more consistent vaporization of eJuices.
The ADVKEN Owl Mesh Sub-Ohm Tanks widest point is 30mm wide with the bubble glass, 24mm base, and stands 38.5mm tall. Pre-Installed on the Owl is the expanded glass tank section that can accommodate 4ml of E Liquid while the included 3ml replacement straight glass segment remains in the package. Filling the Owl Mesh Sub-Ohm Tank is easy by locating the triangle located on the top and pushing it open, located under is a single kidney sized fill port. Included with the Owl are two mesh coil heads— the 0.2 ohm mesh coil is recommended to be used at 50 to 70W (pre-installed) while the 0.16 ohm mesh coil is recommended at 60 to 80W. Other Coil Head that the Owl can use is the Dominator Tank Coil Head, TFV8 Baby Beast Coil Head, TFV8 Big Baby Beast Coil Head, TFV12 Baby Prince Coil Head, and finally the Vaporesso Tank Replacement Coil Head. Located on the top of the Owl Mesh Sub-Ohm Tank is the Airflow Control Ring along with dual airflow slots measuring at 11mm by 3mm. The location of the airflow nullifies the Owl Mesh Sub-Ohm Tank from leaking and condensation all together. A Bullet Shape 810 PEI Drip Tip sits above the Owl, measuring at a 6mm, it sits flush with the atomizer. Other things the ADVKEN Owl Mesh Sub-Ohm Tank comes with are replacement O-Rings and a cleaning cloth. Following its predecessor the Manta Sub-Ohm Tank, the ADVKEN Owl Mesh Sub-Ohm Tank improves on many aspects ranging from design while maintaining the versatility and option to use more than the proprietary coils it comes with.
[img=555x496]https://worldvaporstore.com/wp-content/uploads/2019/03/1-ADVKEN-OWL-MESH-SUB-OHM-TANK.jpg[/img]
[th]Main features[/th]
[th]Product Details[/th]
[th]Package Contents[/th]
Brand: Advken
Model: OWL Mesh
Type: Rebuildable Atomizer
Rebuildable Atomizer: Tank
Material: Glass,Stainless Steel
Thread: 510
25mm Diameter
3mL Standard Juice Capacity
4mL Bubble Glass Capacity
30mm Widest Bubble Glass Diameter
Pyrex Glass Reinforcement
6mm Bore PEI 810 Drip Tip
Stainless Steel and Glass Construction
Gold Plated Contact Pin
Superior Stainless Steel Chassis Construction
Sliding Top Refill System – Push Top
Advken OWL Mesh Coil Family
0.16ohm Mesh Coil – rated for 60-80W
0.2ohm Mesh Coil – rated for 50-70W
Knurled Top Airflow Control Ring
Color: Stainless Steel, Matte Black, Gold, Rainbow, Blue, Coffee, Purple, Green
1 * ADVKEN Owl Mesh Sub-Ohm Tank
1 * Spare 3ml Glass Tube
1 * Pre-Installed 0.2 ohm Mesh Coil Head
1 * Spare 0.16 ohm Mesh Coil Head
1 * Accessory Bag
1 * Microfiber Cleaning Cloth
1 * User Manual
