SMOK Novo 2 Kit
SMOK Novo 2 Kit
Сообщение sihang » 06 сен 2019, 11:18
Зарегистрируйтесь, чтобы увидеть ссылку! 2 Kit
Description:
Novo 2 Kit from SMOK is the upgraded version of Novo. It is powered by built-in 800mAh battery. It is designed with mini and light size, which can be easily taken with yourself everywhere. There are air-intake grooves on both sides of the device, when you inhaling, a double U-shaped air flow path will be formed, which can greatly increase the vapor and purity of taste. The structure of air-sensing switch has been redesigned to make every puff worth. Designed with a groove around the electrode, you don’t need to worry about it flows everywhere. Featuring the lED indicator, you can clearly know the device’s battery conditions according to different light colors. The included pod has dual coils inside for vaporizing more e-juice and producing massive vapor. It is also compatible with NOVO Pod Cartridge. It provides multiple protections to guarantee safe and stable vaping. Available in 9 colors.
Colors: 7-Color Shell, 7-Color Spray, Green and Red, Yellow and Purple, Red and Yellow, 7-Color, Blue and Black, Black and White, Blue and Brown
[img=677x380]https://worldvaporstore.com/wp-content/uploads/2019/07/1-138.png[/img]
[th]Main features[/th]
[th]Package Contents[/th]
Brand:SMOK
Battery Capacity:800mAh
E-liquid Capacity:2.0ml
LED indicator light for displaying the battery level
Size 88.3*24.5*14.5mm
Resistance of Pre-installed Pod 1.0Ω
Input Voltage 3.3V-4.2V
Output Wattage 6W-25W
Charging Current 0.55A (MAX)
Charging Voltage 5V
Overcharge Voltage 4.3V
Overdischarge Voltage 2.4V
Overcharge Current 1A
Output Voltage 3.0V-4.0V
Compact design, easy to take it everywhere
Double U-shaped air flow
Novo 2 Pod with dual coils inside for great MTL vaping
Multiple protections to avoid potential risks
Compatible with both NOVO and NOVO 2 Pod Cartridge
1 * Novo 2 Device
1 * Novo 2 Mesh 1.0Ω Pod(No e-liquid)(2ml)
1 * Novo 2 DC 1.4Ω MTL Pod
1 * USB Cable
1 * User Manual
Authentic Smoktech SMOK Infinix 2 15W 450mAh Starter Kit
