| Decorative vinyl floor is called SPC Flooring ,Rich Color Options We offer a variety of ready different colors and grains for selection . If nothing impress you , do not worry , we can always customize your favorite. SPC flooring specification ColorWe have several hundreds of color for your choice. Thickness4mm ,5mm,5.5mm, 6mm SPC flooring Size:620x310 mm, 920x155 mm, 1220x182 mm etc. Top wearlayer0.3mm, 0.5mm, 0.7mm Special treatmentPainted V-groove, soundproof IXPE Surface treatmentDeep embossed, EIR, Crystal,Wood grain, Flat,Stone Material100% virgin material Click systemUnilin click system or I4F click system Installation MethodFloating 100% waterproof of SPC flooring EPL SPC flooring is 100% waterproof, which you can install on every room in your home. Anti-Scratch of SPC flooring EPL SPC flooring use the new technology UV paint, which contains metallic oxide. Tain Resistance of SPC flooring The surface of EPL SPC flooring is covered by PE wear layer, and specially treated with a special and double-layer UV coating. The UV paint ofEPL is top and special technology in China, which is stain resistance enough. Anti Cigarette of SPC flooring The new technology UV coating will protect the surface, the high temperature of burning cigarette get no influence on the UV coating, and also no destroy of surface of SPC flooring. FAQ 1. Q: How do I know that your floor is consistent with your description? A: Our principle is quality first, free samples are available for your evaluation. Each production step is strictly controlled by the quality control team and can send floor scores, CE certificates and SGS for your reference. 2. Q: Can you provide a sample book to help me promote it? A: Yes, we can design and provide sample books to help you promote. We believe that if you sell well, then we sell well. 3. Q: What is your minimum order quantity? A: MOQ: regular color 500sqm custom color 3000sqm6mm SPC Flooring suppliers website:http://www.eplfloor.com/spc-floor/6mm-spc-flooring/ |
Сообщение dfgjt76 » 18 сен 2019, 04:18
Вернуться в «Ремонт своими руками (Статьи)»
