China Floor And Wall Accessories manufacturers
tgyg55
Сообщение tgyg55 » 05 ноя 2019, 03:58
Some wall panel accessories like Angle line. it beads play an important role in a project. Because the wall corner is always damaged easily in the process of Constitution. The corner beads can streng then the wall of firmness.
It is convenient,easy and fast, so it can help the project save a lot of time
SPC flooring specification
ColorWe have several hundreds of color for your choice.
Thickness4mm ,5mm,5.5mm, 6mm SPC flooring
Size:620x310 mm, 920x155 mm, 1220x182 mm etc.
Top wearlayer0.3mm, 0.5mm, 0.7mm
Special treatmentPainted V-groove, soundproof IXPE
Surface treatmentDeep embossed, EIR, Crystal,Wood grain, Flat,Stone
Material100% virgin material
Click systemUnilin click system or I4F click system
Installation MethodFloating
100% waterproof of SPC flooring
EPL SPC flooring is 100% waterproof, which you can install on every room in your home.
Anti-Scratch of SPC flooring
EPL SPC flooring use the new technology UV paint, which contains metallic oxide.
Tain Resistance of SPC flooring
The surface of EPL SPC flooring is covered by PE wear layer, and specially treated with a special and double-layer UV coating. The UV paint ofEPL is top and special technology in China, which is stain resistance enough.
Anti Cigarette of SPC flooring
The new technology UV coating will protect the surface, the high temperature of burning cigarette get no influence on the UV coating, and also no destroy of surface of SPC flooring.
FAQ
Q1: Can you produce products according to your requirements?
Yes, we can do all the products according to the requirements of the guests.
Q2: How is the delivery time?
It depends on the quantity. In general, it takes about 25 days after receiving the deposit. If you are in urgent need of goods, we will try our best to shorten the delivery time.
Q3: Can you accept small orders?
To be honest, it depends on cost and technology, but we will try our best to accept small orders and build long-term business relationships with our customers.
We have been one of the most trusted flooring manufacturers in the industry for many years. We are always working to develop the most innovative, aesthetically pleasing and easy to install flooring. Our commitment to superior quality and unparalleled customer service sets us apart from the crowd.China Floor And Wall Accessories manufacturers
website:http://www.eplfloor.com/floor-and-wall-accessories/
Вернуться в «Новостройки Подмосковья на расстоянии до 15 км от МКАД»
