| The pressure of QGB heavy duty pneumatic Lift Air cylinder is above 25 MPa, so that the height of the sealing element of the equipment to a certain extent determines the size of the deformation of the sealing element root, the size of the extrusion gap of QGB cylinder, because the gasket also has hardness and deformation, plus its gasket is equal to reduce the deformation of the sealing element. When the seal of QGB cylinder is under high pressure, the root is removed to reduce the possibility of friction with the piston rod and the inner wall of the cylinder body, so as to reduce the possibility of damage of the seal root caused by extrusion strain to a certain extent. The relationship between the hardness of the washer in the equipment and the pressure is that the greater the pressure, the greater the hardness. Parameter Main feature: 1. The width of the root of the dual-purpose seal of QGB cylinder is smaller than that of the special seal. When the equipment is under high pressure, the deformation of the root of the dual-purpose seal is relatively large. When the special seal is under the same pressure, its root is relatively wide and its compression deformation is relatively small. 2. QGB cylinder needs to choose its special seal, if the shaft seal in the equipment, can only choose a special seal shaft, the piston seal can only choose a special seal piston, in the use of the process can not choose the shaft and piston dual-use seal. 3. QGB cylinder throttle valve mouth opening size, to a certain extent, can effectively control the amount of its exhaust, so it will determine the size of the pressure in the compressed volume, so as to adjust the buffer effect, if you make the piston reverse movement, the input of compressed air from the stoma, can directly open the one-way valve.Linear Pneumatic Cylinder suppliers website:http://www.akpneumatic.com/pneumatic-cylinder/linear-pneumatic-cylinder/ |
Сообщение czyhmblfn » 03 дек 2019, 04:22
Вернуться в «Купля-продажа, аренда недвижимости»
