Characteristics Adopt photoelectric turbidimetry method; monitor the process of clotting coagulation. Special intelligent software, no influence from pathological sample during the test. Open reagent systems Micro reagent and sample volume for less use-cost。 Timer will start automatically when absorbance is changed,no need of adapter. When test FIB by clauss method, test directly instead of FIB calculating, decreasing theoretical error. Main Test Items PT, APTT, TT, PT, Ⅱ, V , VⅡ, X, Ⅷ, Ⅸ, Ⅺ, Ⅻ Specifications Prewarming position: 12 Optic block: 1, 2, 4 Reagent position: 3 Light source: LED Temperature control: 37 ± 0.5℃ Calculate function: conversion with sec, INR, mg/dl Calibration curve: by-hand input, automatic saving, automatic transferring Display: 128 * 64 LCD screen Printing system: Thermal printer can print automatically or manually. Interface: RS 232 interface Power supply: AC220V ± 22V, 50Hz ± 1Hz Power: ≤ 60W Dimension: 360(L) mm × 300(W) mm × 110(H) mm Weight: 5.25 Kg We are professional as one of the leading sclot series coagulation analyzer manufacturers and suppliers in China. Welcome to wholesale the high quality and durable laboratory equipment from our factory. And good after-sale service and timely delivery are offered.China Hematology Apparatus suppliers website:http://www.sumerinstrument.com/medical-equipment/hematology-apparatus/ |
Сообщение changkong » 06 янв 2020, 06:01
