| Descriptions Among the large amount of by-products in the brewery, the largest production is wet distiller's grains. However, wet distiller's grains are prone to deterioration, so it is easy to pollute the environment during transportation and storage. The distiller's grains dryer can quickly dehydrate and dry the wet distiller's grains with a moisture content of about 85% to a dry product with a moisture content of about 10%. At present, the equipment has been put into use by many beer companies and feed processing enterprises at home and abroad,and has created considerable economic benefits. Working principle After the dehydrated wet distiller's grains entering the dryer,it is evenly dispersed in the dryer and fully contacted with hot air under the flapping of the uniformly distributed sheets in the drum. Then, under the action of the inclined plate and the heat medium,the finished distiller's grains are discharged from the star-shaped discharging valve at the other end of the dryer. The dust collector will collect the dust generated during the drying process. Structure The distiller's grains dryer is mainly composed of the heat-supply system, the feeding system, the drying system, the discharging system, the dust-collecting system, and the electronic control system. Characteristics 1.Good uniformity of product drying process. 2.Excellent and simple structure. The material runs smoothly through the cylinder. 3.Easy to operate. 4.Low failure, low maintenance costs, and low power consumption. 5.High degree of mechanization, large capacity, and continuous operation. Specifications ModelCapacity (t/h)Water content of input (%)Water content of output (%)Host power (kw)Heat consumption (kcal/h)Water evaporation (t) Φ1200x100001-1.565±5≤107.5≥60000.61 Φ1500x120002-465±5≤1011≥60001.32 Φ1500x150002.5-565±5≤1015≥60001.53 Φ1500x180005-865±5≤1015≥60001.83 Φ1800x180008-1265±5≤1018.5≥60003.61 Installation siteRotary Dryer suppliers website:http://www.ny-machine.com/rotary-dryer/ |
Сообщение clou2190 » 19 фев 2020, 15:50
