| ● Part Name: Plastic Cabinet Injection Mould ● Cavity / Core: 1.2738 ● Mould Cycle Time: 60 Seconds ● Mould life: 800K Long Slide is the typical feature for the plastic cabinet mould, good mould design, precise component size and good quality hydraulic cylinder is the assurance of good mould in Zheao. Work Process Why Choose Us: ● Mould design will be optimized by experienced designer and reviewed by the whole team. ● By minimize the lead time, optimize the machining process, we are trying to provide the competitive mould price without reduce the mould quality. ● For better communication with customer, our sales engineer are trained in design dept, production dept and project dept for more than 3 monthes each. ● 18 years rich experience on mold industry and a wide range of products FAQ: Q: How many mould tests will be needed before shipment? A: Usually, it will be 3 times mould tests, with T1 test to check generally the part size, mould fuction. With T2 to improve the part and mould function. With T3 to confirm the sample and finalize the mould. Q: What’s the mould adjustment cost if I decided to change the part design? A: It depends, if the design change is not so bigger, we can offer the adjustment for free, if it is big modification, then we will charge according to the exact work. Q: My mould is very heavy, we are worried the wooden package is not strong enough, what can you do? A: We can make steel crate for some heavy mould specially, then on top covered with wooden box.Cabinet Mould Made in China website:http://www.zheaomould.com/houseware-mould/cabinet-mould/ |
Сообщение clou2190 » 19 фев 2020, 15:51
[hr]
