| 1) High Temperature Resistances (-260-300鈩?; 2) Good Hydrolysis Resistances; 3) Material 304/316L/Carbon Steel; 4) Guarantee Quality of the Parts. 1. Product Introduction Venturis are cone-shaped devices located at the top of a tubular filter bag in a Pulse Jet Dust Collector. At the top of the venturi, it creates a negative pressure for pulling additional air down into the filter elements during pulsing. We offer a full line of properly engineered venturis, available in various materials of construction including spun aluminum, steel and stainless steels. 2.Product Parameters (Specification) Product nameFilter Bag Venturi Size1脳145脳140 mm MaterialSteel Alloy: carbon steel/ carbon steel to be zine Process TechnologyCasting, Machining, Metalworking, Sheet Metal Bending, Surface Treatment, Heat Treatment, Griding, Milling, wire EDM, Linear Cutting etc. Surface TreatmentBlacking, Polishing, Anodize, Chrome plating, Zinc plating,Nickel plating, Tinting, Power coating, E-coating etc 3.Product Feature And Applications 1)Quality Control: The defective products rate is 0.1%. Imported material 100%. 2)Reasonable price. 3)Each part would be given 100% test and tryout before shipment. 4)Adequate supply capacity. Punctual delivery time. 5)Best after sales service is provided.Filter Accessories factory website:http://www.entexfiltration.com/filter-accessories/ |
Сообщение fish56a » 02 мар 2020, 00:15
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 4 гостя
