Power:300w Resistance Range: 1-12Ohm Size:266*36mm weight :410g The Chief Characteristic: On shape ceramic tube fixed two leading-out terminal, ceramic tube on the winding resistance of copper and nickel or nickel chromium alloy wire, and on the surface with high temperature resistance of incombustible resin coating, coating for air-dried, via high temperature treatment after fixed resistor body insulation, and equipped with a fixed frame. Applications: mechanics, electronics, metallurgy, mining, petrochemical, transportation, building materials, municipal, metal processing, textile, printing and dyeing, paper making, Injection machine, central air conditioning, numerical control machine tool, air-compressor, fan and pump, blower, air conditioner for large buildings; wastewater treatment system; water supply system for large buildings; public water supply system and other industries and fields. The Contour Drawing of 300 watt resistors The Chief Technology Parameters & Contour Dimensions Type Power(w) Resistance Range(Ω) Contour Dimension (mm) Weight (g) RXHG -A LL1L2ΦDHtΦdB1B 801-5.1140±3.2170±4182±430±364±36±13.56.526263 1001-6.2170±3.5200±4212±430±364±36±13.56.526290 1501-8.2215±4.0245±4257±430±364±36±13.56.526395 2001-10266±3.0296±4308±430±372±39±14.06.526485 3001-12266±3.0296±4310±436±384±39±14.06.534640 4001-20250±2.0290±3312±454±394±316±18.07.0481000 5001-51300±2.0340±3362±454±394±316±18.07.0481350 RXHG -B 800.5-5.1140±2.0162±3174±432±376±312±15.56.528133 1000.5-6.2170±2.0192±3204±432±376±312±15.56.528160 1500.5-8.2215±2.0237±3249±432±376±312±15.56.528205 2001-10266±2.0288±3300±432±376±312±15.56.528255 3001-12266±2.0288±3302±436±388±312±15.56.534410 4001-20250±2.0280±3302±454±3102±315±16.57.048770 5001-51300±2.0330±3352±454±3102±315±16.57.0481040 10001-68300±3.0332±4362±472±3128±316±16.59.0683000 15001-100420±3.0452±4482±472±3128±316±16.59.0684000 20001-120520±3.0552±4582±472±3128±316±16.59.0685000 25001-150600±3.0632±4662±472±3128±316±16.59.0686000 30001-150700±3.0732±4762±472±3128±316±16.59.0687000 The Power Derating Curve of 300 watt resistors Our Services If you find any quality problems. please send it back within 3days. and we'll send you a new one or refund you the payment. 2.Buyers have to pay for the return cost and we will pay the cost for resend. 3.All products returned are in new conditions. Feedback: A good feedback is very important for my store, If you feel satisfied with my product and service. Pls give us a positive feedback. Pls contact us before leaving any negative or neutral feedback. we will work with you to solve any problems. wholesale Wire Wound Resistors website:http://www.qhresistors.com/wire-wound-resistors/ |
Сообщение damimi721 » 12 мар 2020, 05:38
