What is Asian Handicap?
Asian Handicap, also known among bettors as handicap betting or simply Handicap, can be applied to almost all sports matches and is popular among many players.
Regarding handicap betting, the term originates from Зарегистрируйтесь, чтобы увидеть ссылку! setting a certain handicap level for a match. The stronger team, favored to win, will have to give a certain number of goals to the opponent on the betting odds board. This implies that they need to score more goals to help the bettor win.
Bookmakers ensure that all betting options have equal winning odds, depending on the difference, and can apply handicap levels such as 0.25, 0.5, 1, 2, etc. These numbers are carefully researched by expert teams and can accurately reflect the dynamics of the match. This also becomes the basis for players to visualize the match and refer to during the analysis process.
Advantages of Asian Handicap over other betting forms
In a football match, various betting forms are often offered to meet the entertainment needs of customers. Among them, Asian Handicap always receives special attention and attracts many bettors to participate. The reasons are:
Creates tension and excitement in every match
Matches with significant gaps often turn out to be quite dull, and viewers almost always know beforehand which side will win. Asian Handicap is designed to address this issue, ensuring fairness for both sides and making the game thrilling every second.
Allows live betting
A unique aspect of this type of bet is live betting. This means players can participate in betting even while the match is ongoing. This improvement aims to provide conditions for players to monitor and reassess the strength of both sides, thereby placing bets more safely.
Easy to participate in
As mentioned earlier, this type of bet can be applied to all matches, not just football but also a variety of other sports.
Capital safety
Another interesting point of Asian Handicap is the method of determining wins and losses. In some cases, players will only lose half of their stake even if they choose the wrong betting option.
Understanding and calculating some Asian Handicap bets
In each match, the difference in the teams' levels will also vary. Therefore, various handicap levels may be offered to ensure that all bets are fair and thrilling. When participating in handicap betting, players need to know how to understand and calculate some types of bets as follows:
Read more: Зарегистрируйтесь, чтобы увидеть ссылку!? How do they operate?
Level Handicap
This is the simplest form, where two teams have similar or negligible skill levels, so no handicap is applied (level handicap). The win-loss determination is extremely basic: players receive rewards if they choose the winning team, and vice versa.
In the event of a draw, the betting result is considered a draw, and players receive a full refund.
Half Handicap
Marked as 0.25 or 1/4, this is a relatively small handicap level, and the win-loss determination is similar to level handicap. The only difference is that if the match ends in a draw, players will win or lose half of their stake. Specifically:
Players betting on the upper option will lose half their stake if the match ends in a draw.
Players betting on the lower option will win half their stake if the match ends in a draw.
Half-ball Handicap
Marked as 0.5 or 1/2, the higher-rated team will be on the upper side and will have to give the opponent half a goal. Participants will choose:
For the upper team: Players can only receive rewards if this team wins the match.
For the lower team: Players will receive rewards if the match ends in a draw, and the lower-ranked team wins the match.
One-ball Handicap
As the name suggests, the stronger team must give the opponent a one-goal lead. Players will choose:
For the upper team: You will only win and receive rewards if this team creates a final goal difference of at least two goals.
For the lower team: You will win if the match ends in a draw or the weaker team wins.
Additionally, if the match ends with a one-goal difference in favor of the upper team, the Asian Handicap at this point will be considered a draw, and 100% of the bet will be refunded to participants.
Tips to gain an advantage when playing Asian Handicap
To make money from Asian Handicap betting, besides understanding the concepts and calculating the handicap levels, you also need additional betting experience. Each bettor will have their own effective playing methods. If you are a novice, just following these guidelines will give you a significant advantage:
Analyze the odds yourself
Although the handicap odds are set by bookmakers and experts before being released, most of the time, they accurately reflect the match result. However, you should analyze and double-check the odds yourself to ensure safety, as there might be some "trap bets".
Choose major tournaments
According to the experience of many professional bettors, major tournaments have lower risk levels. Firstly, the skill level difference between teams is not too large, and the applied handicap is small, making it easier for players to choose bets. Secondly, bookmakers seem unable to manipulate or intervene in the results of international matches, ensuring a safer participation.
Choose the right time to place bets
For Asian Handicap bets, the "golden time" to place bets is within 15 minutes of the first half. At this time, players have enough time to observe the on-field changes realistically and verify their judgments. Once you have grasped all the information about the match, choosing the winning handicap becomes quite easy.
Conclusion
For sports enthusiasts who want to experience thrilling matches, Asian Handicap is undoubtedly an excellent choice. To receive the best quality bets with the most attractive odds, don't hesitate to access and participate today.
