Each season, over-under in football becomes a captivating game that attracts the attention of betting enthusiasts. Although it's widely discussed and has high coverage, not everyone fully understands what over-under in football is and how to calculate it. So what exactly is over-under in football? How is it calculated? Let's find out in this article!
Being a favorite form of betting for many enthusiasts, over-under in football always has its own allure, making players eagerly await each minute from kickoff to the final whistle. This article will introduce and explain various aspects of this intriguing gambling discipline.
1. What is Over-Under in Football?
Over-under in football is a form of betting where the outcome depends on the total number of goals scored by both teams within the official 90-minute match period. With this form, bookmakers offer odds for each match so that players can bet on either the "over" or "under" outcome.
Through observation, analysis, and a bit of luck, players need to calculate the total number of goals to decide their bets. If they choose "over," it means the total score will exceed the odds set by the bookmaker, and vice versa for "under." With this form, players don't need to worry about the win or loss of the two teams; what matters is the total number of goals scored in each match.
2. How to Calculate Over-Under Odds in Зарегистрируйтесь, чтобы увидеть ссылку!
In reality, calculating over-under odds is quite simple, depending on different odds. To understand better, let's look at the examples below:
2.1. Over-Under Odds 1.5
This over-under odds mean that if the total number of goals scored in the match does not exceed 1, those who bet on "under" will win. Conversely, if the total goals scored exceed 1, those who bet on "over" win the full bet amount.
The amount won in a 1.5 odds bet is calculated as follows:
Winnings=Bet amount x Odds set by the bookmaker.
2.2. Over-Under Odds 1.75
In this case, if the total number of goals scored in the match is less than one, the "under" bet wins, while if the total goals scored are three or more, the "over" bet wins.
Additionally, if the total number of goals scored is 2, players who bet on "over" or "under" will only win/lose half of the bet amount.
Winnings/Losses=Bet amount x 0.5.
2.3. Over/Under 2 goals
In the Over/Under 2 goals bet, if the total number of goals scored on the field does not exceed 2 goals, then the "Under" option wins. Conversely, if the total number of goals scored on the field exceeds 2 goals, then the Зарегистрируйтесь, чтобы увидеть ссылку! option wins. In this case, the winnings are calculated as in previous bets.
2.4. Over/Under 2.25 goals
With this bet, if the total number of goals on the field does not exceed 1, then the "Under" option wins. If the total number of goals on the field is 3 or more, then the "Over" option will win. In this case:
Winnings=Bet amount * Odds
However, if the total number of goals scored on the field is 2, then the player who bet on "Over" will lose half of their bet amount. The player who bet on "Under" will win half of the bet amount, where the bet amount is multiplied by the odds.
Winnings=Bet amount x 0.5 + Bet amount
2.5. Over/Under 3 goals
With this bet, if the total number of goals on the field is less than 3, then the "Under" option wins. If it's three or more, then the "Over" option wins. In the case where the total number of goals scored on the field is 3, both options result in a tie. The winnings are calculated as follows:
With the specific information and examples provided by above, it's hoped that readers understand how to bet on over/under in football and the payout ratios for winning.
Additionally, to keep track of the matches you've bet on, you can use VTVCab - an application for watching live television on your phone or computer to follow matches happening around the world. If you're unfamiliar with how to use VTVCab, you can follow the instructions shared below.
Conclusion: A Guide to Football Betting
In conclusion, successful football betting requires discipline, strategy, and a thorough understanding of the game. By avoiding continuous betting on multiple matches and instead focusing on well-researched selections, you increase your chances of making accurate decisions.
It's crucial to manage your betting capital wisely, setting clear limits on the number of bets and the amount of money you're willing to wager. This helps protect your funds and prevents reckless betting behavior.
Additionally, don't be swayed by popular opinion or follow the crowd blindly. Take the time to gather information, build experience, and develop your own judgment to make informed betting choices.
You can refer to the article: Зарегистрируйтесь, чтобы увидеть ссылку!
Finally, familiarize yourself with different betting methods such as surebets and the Martingale system, but always use them responsibly and within your predetermined limits.
With these guidelines in mind, you can approach football betting with confidence, knowing that you're making calculated decisions and maximizing your chances of success. So, go ahead, apply these principles, and enjoy the thrill of football betting responsibly.
