Understanding TF88 Over/Under Betting in Online Football Betting
qiqi77246
Сообщение qiqi77246 » 13 июл 2024, 06:47
There are many popular forms of online betting that experts in the field often refer to, such as Asian Handicap, Handicap Betting, Over/Under betting, and others. Among these, one of the most commonly played by professional Зарегистрируйтесь, чтобы увидеть ссылку!. But do you fully understand how to play the Over/Under bet? How does the Over/Under bet work in football betting? The following article will address common questions that newcomers to online betting frequently have about the Over/Under bet in football betting.
What is the TF88 Over/Under Bet?
The TF88 Over/Under bet, also known as the Over/Under (O/U) bet, is the most popular type of bet applied at TF88 bookmakers. Before participating in placing the odds for each football match, the bookmaker will give a certain number, and you can bet higher (Over) or lower (Under) than the number provided by TF88.
The TF88 Over/Under Bet in Football Betting
For the Over/Under bet in football betting, TF88 bookmakers apply this type of bet based on the total number of goals scored, the total number of throw-ins, the total number of corners in a match, etc.
When you choose to play the Зарегистрируйтесь, чтобы увидеть ссылку!, you only need to pay attention to the total number of goals scored after the match and compare it with the odds provided by TF88 to determine whether you win the bet.
Example to Help You Understand Better:
If TF88 sets the odds at 3.75 for a match between Bayern and Stuttgart:
If the match ends with a total of 5 goals and you bet on Over, you win money, or if the total goals are 4, you win half the money.
If the match ends with a total of 2 goals and you bet on Under, you win money, or if the total goals are 3, you win half the money.
The amount you receive will be multiplied by the corresponding odds provided by TF88. For example, if you win the Over bet: 100 x 0.88 = 88k.
The TF88 Over/Under bet only applies to the official 90 minutes and a few minutes of stoppage time, not counting extra time and penalties.
How to Read TF88 Over/Under Odds in Football Betting
You will often encounter odds like 2 goals, 2.25 goals, 2.5 goals, 2.75 goals, 3 goals, 3.25 goals, etc. So how are these numbers understood?
Over/Under 2 Goals:
This bet is relatively simple. If you bet on Over and the total goals after the match are more than 2, you win money.
If you bet on Under and the match ends with fewer than 2 goals, you win money.
If the match ends with exactly 2 goals, the bet is a draw, and TF88 will refund your money.
Over/Under 2.25-2.5 Goals
For this type of bet, it works as follows:
If the total goals after 90 minutes are more than 3 and you bet on Over, you win full money. If the result is 2 goals, you win half the money.
If the total goals after 90 minutes are fewer than 2 and you bet on Under, you win full money. If the total goals are 2, you win half the money.
Over/Under 2.75 Goals
For the 2.75 goals bet, it works as follows:
If the total goals after 90 minutes are more than 4 and you bet on Over, you win full money. If the result is 3 goals, you win half the money.
If the total goals after 90 minutes are fewer than or equal to 1 and you bet on Under, you win full money. If the result is 2 goals, you win half the money.
For bets with 3 goals, 3.25 goals, 3.75 goals, we understand them similarly to the above bets.
TF88 Over/Under BTI
The TF88 Over/Under bet has many other variations, such as the first half Over/Under, full match Over/Under, corner Over/Under, throw-in Over/Under, etc. I will introduce these types in a future article so you can understand how to place bets for these types.
Some Notes When Participating in TF88 Over/Under Betting in Football
When you participate in betting on a match you like and want to bet on Over, it is advised to wait until after the 10th minute to place your bet because very few goals are scored in the first 10 minutes.
Choose top leagues like EPL, La Liga, Bundesliga, etc., to place your bets.
If you want a high winning rate, you should closely follow the match.
Choose reputable bookmakers to place your bets.
Conclusion
TF88 Over/Under betting offers a straightforward yet engaging way to participate in football betting. Understanding how to read and apply different Over/Under odds can enhance your betting strategy and increase your chances of success. Whether you are a newcomer or an experienced bettor, comprehending these odds and applying them effectively can make your betting experience more rewarding. Follow the Зарегистрируйтесь, чтобы увидеть ссылку! provided, keep track of the matches, and always choose reputable bookmakers to ensure a fair and enjoyable betting experience.
