Quick Detail Rated Voltage: 240V/360V/384V Maximum Current: 150A/200A/250A/300A Display: 3'' LCD Screen Connection port: Waterproof Accessories: Charger Adapter Supply Ability: 8000 Piece/Pieces per Month solar system PWM battery charger controller Packaging & Delivery Packaging Details Carton or wooden for Big charging current 150A/200A/250A/300A solar system PWM battery charger controller Port: Shanghai or Yangzhou Lead Time: Shipped in 3 days after payment Product Characteristic: The solar charge controller adopts industrial-grade chips to ensure the stable feature of controller Excellent EMC design High efficient PWM charging technology which has three charging stages (buck charging stage, equalize charging stage and float charging stage), and improves battery storage efficiency and charging efficiency. Advanced battery activation technology which increases battery lifetime 30% at least and improves the system performance The 30A to 300A solar charge controller adopts imported IGBT power module or MOSFET as electronic switch which can improve the stable performance of controller. There aren’t any mechanical switches in the system LCD will display the system status and working parameters Parameters setting flexibly Users can parallel connect lots of the controller is a system Fully enclosed duct design and high speed fan for cooling making the controller working in a variety of harsh environments DC output function (Optional) Standard Modbus protocol for RS-485 communication to extend the communication distance (Optional) The solar charge controller will alarm when the system status is abnormal New SOC method displays battery power accurately With power generation statistics function to facilitate the view of power generation of daily, month and total. There is temperature compensation function which will compensate the temperature according to different battery type. The solar charge controller adopts graphical dot-matrix LCD and 4 buttons as HMI for full menu and easy operation RTC time function. Parameters of 150A to 300A solar charger controller System voltage BZC-: 24V, 48V, 96V, 192V, 240V, 360V, 480V, 540V, 600V Max. VOC of PV arrays: 100V, 100V, 200V, 350V, 450V, 700V, 950V, 1000V, 1000V Rated charging current: 150A, 200A, 250A, 300A, 350A, 400A Equalize charging point: 28.8V, 57.6V, 115.2V, 230.4V, 288V, 432V, 576V, 648V, 720V Equalize charging recovery point: 26.4V, 52.8V, 105.6V, 211.2V, 264V, 396V, 528V, 594V, 660V Equalize charging time: 120 minutes (default setting) Float charging point: 27.6V, 55.2V, 110.4V, 220.8V, 276V, 414V, 552V, 621V, 590V Over voltage point: 32V, 64V, 128V, 256V, 320V, 480V, 640V, 720V, 800V Over voltage recovery point: 30V, 60V, 120V, 240V, 300V, 450V, 600V, 675V, 750V Stand-by consumption: <0.5W Display: 3'' LCD Display language: English Terminal type: TC series barrier terminal Elevation: <4000 meter, should reduce power if the elevation high than 4000 meter Humidity: 0~98%, non-condensing Protection level: IP32 Noise: <30dBA Cooling method: High speed fan + heat sink Environment temperature: -25°c~55°c Dimension: 900*520*500 Net Weight: 75KG What is PWM charge controller: PWM (Pulse-Width Modulation) is the most effective means to achieve constant voltage battery charging by switching the solar system controller's power devices. When in PWM regulation, the current from the solar array tapers according to the battery's condition and recharging needs.low price PWM Solar Charge Controller website:http://www.fsypvenergy.com/solar-controller/pwm-solar-charge-controller/ |
(Здесь собраны новостройки из ТАО)
Сообщение astao47 » 25 июл 2019, 12:14
Вернуться в «ТАО - Троицкий административный округ»
