Marvec MV Pod Kit 400mAh Sticker Standard Edition
Сообщение sihang » 23 авг 2019, 11:55
Зарегистрируйтесь, чтобы увидеть ссылку! Pod Kit 400mAh Sticker Standard Edition
Main Features:
Resistance: 1.5 ohm
Capacity: 2.0ml
Battery capacity: 400mAh
Output mode: M ( manual ), A ( automatic )
Connect the mod to the safe power source through the USB cable for charging, the screen displays charging, the screen goes out after full charge, and supports simultaneous charging and working
Ergonomic design for comfortable grip
Color:Black
[th]General[/th]
[th]Dimensions and Weight[/th]
[th]Package Contents[/th]
Brand: Marvec
Type: E-Cigarette Starter Kit
Material: ABS
APV Mod Wattage: 10W
Atomizer Type: Clearomizer
Battery Capacity: 400mAh
Product weight: 0.0260 kg
Package weight: 0.0650 kg
Product size (L x W x H): 8.90 x 2.48 x 1.47 cm / 3.5 x 0.98 x 0.58 inches
Package size (L x W x H): 12.00 x 5.00 x 3.00 cm / 4.72 x 1.97 x 1.18 inches
1 x Battery Mod
2 x Pod Atomizer
1 x USB Cable
1 x English Manual
