Зарегистрируйтесь, чтобы увидеть ссылку! Sub Ohm Tank Atomizer
Description
Eleaf ROTOR Sub Ohm Tank Atomizer features Eleaf first introduced innovative turbine system with built-in small propeller, producing vortex in airflow, and it is designed with HW-T 0.2ohm coil and HW-M 0.15ohm, which will offer you smoother clouds and flavor. Besides, there is no spit-back, atomized any vapor droplets because any vapor droplets that are not properly atomized hit the propeller, and are driven centrifugally back onto the mesh heater element to be atomized again. And you just need to press and slide the device, which is very easy to operate. Moreover, it is very convenient for you because of its top filling system. What’s worth mentioning that Eleaf ROTOR Atomizer comes with a smart child resistant lock system to avoid accidental opening and leakage.
Color:Black, Silver, Blue, Dazzling
[img=388x397]https://worldvaporstore.com/wp-content/uploads/2019/08/2-8.jpg[/img]
Main features
Size: Diameter: 26mm(Atomizer base) Diameter: 28mm(5.5ml glass tube)
Height: 56mm
Capacity: 5.5ml / 2ml
Resistance: 0.2ohm
Package Contents
5ml
1 x ROTOR Atomizer (5.5ml)
1 x HW-T 0.2ohm Coil
1 x HW-M 0.15ohm Coil
1 x User Manual
2ml
1 x ROTOR Atomizer (2ml)
1 x User Manual
