Innokin Adept 17W 3000mAh Kit With Zlide D22 Tank
Description
The Зарегистрируйтесь, чтобы увидеть ссылку! 17W Starter Kits with Zlide D22 Sub Ohm Tank, which is designed for the mouth to lung(MTL) vaping. it includes the Adept Mod and Zlide Tank. the Innokin Mod features the soft-touch rubberized finish and certified IP67 waterproof, dustproof and shockproof. the Adept Mod built-in 3000mah battery and max output 17watts, with the 2A micro USB quick charge design and tri-color LED indicator light. with the auto-selects wattage range, the select button cycles through four optimized wattage levels on an easy to read LED display. the Zlide Tank with 2ml e-juice capacity, compatible with the zenith series coil heads and comes with the Z-plex3D mesh coil for the incredible flavor and vapor production. with the convenient slide-to-side top e-juice refill design, easy to fill your favorite e-juice without leakage.
Colors: Purple, Black, White, Ocean, Sky, Forest Camo
[img=713x500]https://worldvaporstore.com/wp-content/uploads/2019/08/1-11.jpg[/img]
Innokin JEM AIO Flavor Vape Pen 13W 1000mAh
