OVANTY Falcon Pod Kit 950mAh
Добавлено: 30 авг 2019, 05:47
Зарегистрируйтесь, чтобы увидеть ссылку! Pod Kit 950mAh
Color:Marble Blue, Red ,Blueberry Blue
Main Features:
Pod capacity: 1.8ml
Coil: 0.5 ohm cotton coil; 1.1 ohm ceramic coil
Resistance range: 0.2 – 1.5 ohm
Battery capacity: 950mAh
Fast charge: DC 5V, 2A
OLED screen size: 0.69 inch
Stand by current: less than 10uA
Compatible with nicotine salt and freebase e-liquid
Main Features:
Pod capacity: 1.8ml
| Brand:Ovanty Material: Tempered glass + zinc alloy material Battery:950mAh Capacity: 1.8ml Charging Cable:USB Size: 90 x 37 x 16mm Resistance:1.1ohm(Ceramic) 0.69-inch OLED screen and easy-operated buttons 950mAh Built-in battery for long time vaping High quality Tempered Glass and lighter Zinc Alloy material High-end workmanship with attractive colors Optional Regular Pod and Ceramic Pod Compatible with nicotine salt and freebase e-liquid |
| 1 * OVANTY Falcon Battery 2 * OVANTY Falcon Cartridge (Regular Pod & Ceramic Pod) 1 * USB Cable 1 * Certification 1 * User Manual 1 * Warranty Card |
