Insulation Material manufacturers
Добавлено: 18 июн 2019, 03:46
| Product Introduction Of The PERFORATED FOIL FACING Perforated foil facing is chosen when the acoustic insulation is required to be fastened to the visible underside of a concrete slab where high acoustics are required. Perforated foil facing is not a new invention but it is becoming very popular in building insulation. It is used to reflect heat where you want it, just like a thermos, hot sides stay hot and cold sides stay cold. By reflecting Radiant Energy back into the home radiant barrier insulation can significantly improve the heat loss of the insulation system. Product Parameter Of The PERFORATED FOIL FACING Product Construction FSK-7160APFoil: 7 micron/ 3-ways scrim (8x12 threads/100mm)/ Polyethylene/ 60gsm Kraft paper Hole diameter: 1.6mm, space between holes: 4mm FSK-7160BPFoil: 7 micron/ 2-ways scrim (12.5x12.5 mm)/ Polyethylene/ 60gsm Kraft paper Hole diameter: 1.6mm, space between holes: 4mm FSKV-7160APFoil: 7 micron/ 3-ways scrim (8x12 threads/100mm)/ Polyethylene/ 60gsm Kraft paper/ Polyethylene Hole diameter: 1.6mm, space between holes: 4mm FSKV-7160BPFoil: 7 micron/ 2-ways scrim (12.5x12.5 mm)/ Polyethylene/ 60gsm Kraft paper/ Polyethylene Hole diameter: 1.6mm, space between holes: 4mm DFC-1001APFoil: 7 micron/ 3-ways scrim (8x12 threads/100mm)/ Polyethylene/ 60gsmKraft paper/ Polyethylene/ Foil:7micron Hole diameter: 1.6mm, space between holes: 4mm Product Feature And Application Of The PERFORATED FOIL FACING The hold diameter can be customized Kraft paper standard weight is 25gsm, 50gsm and 60gsm. Typical width: 1.0m、1.1m、1.2m、1.25m、1.3m Length: 100m、300m、1000m Inner core: 76mm Perforation through FSK series and heat sealing series and double sided reflective foil, mainly used as vapor barrier with foam insulation, also as sarking and insulation under roofs, timber floors. And reduction noise absorption for industrial building。 Production Details Of The PERFORATED FOIL FACING Packing & shipping Insulation Material manufacturers website:http://www.fanryntech.com/insulation-material/ |
