two qualifying matches on
Сообщение jinshuiqian0713 » 24 дек 2019, 05:18
Got a question on rule clarification, comments on rule enforcements or some memorable NHL stories? Kerry wants to answer your emails at cmonref@tsn.ca. Hi Kerry, Ive been a huge fan of you and your hair for as long as I can remember. Loved your book and the insights you give in your columns. In regards to the disputed goal by the Red Wings during their game versus the Kings on Saturday, can you provide some insight as to how the on ice officials made their determination?From what Ive read, there seems to be two different thoughts on why a goal was allowed with a puck that was clearly out of play. One, none of the on ice officials saw the puck clearly hit the safety netting so the call on the ice stands, a goal. Two, on ice official(s) did see the puck hit the safety net, but as none of them blew the play dead (or intended to), the play was still active and whether or not they saw it hit the net is irrelevant. The call on the ice stands as the play was active and cant be overruled. Both reasons center around the fact that no video review was allowed so the call on the ice had to stand. In an age where basic things like boundary violations can easily be determined with video review, when is the NHL going to change things to expand video review for goals? Thanks for your great work and insights. Sincerely,Kurt JordanEncinitas, CA Kurt: To answer your first question, you can take it to the bank when I tell you that none of the four officials on the ice saw the puck strike the fan-friendly protective netting above the end zone glass. If one of the crew had witnessed the puck leave the playing surface (or even came to that conclusion through self-reflection) a goal would have subsequently been disallowed in spite of the fact that the whistle had not blown. The officials intent to blow the whistle would prevail to ensure that the correct call was made. When the play occurred in real time, I was bombarded with questions on Twitter as to how four officials can possibly miss this call. I hope you will understand there are times when it is next to impossible to track the puck at ice level. The perfect storm resulted on this play after Niklas Kronwalls slapper was blocked by Jarret Stoll causing the puck to rocket into the upper atmosphere of the Joe. Referee Rob Martell was appropriately focused on Todd Bertuzzi and the action in and around Jonathan Quick. The other three officials attempted to locate the puck in its flight path. Please dont suggest that the whistle should have immediately blown because these three officials lost sight of the puck. A reasonable time frame is allowed to make sure the puck is either frozen or out of play in an effort to avoid a premature whistle. The very best angle to track and detect the puck hitting the protective net was enjoyed by Kings defenceman Drew Doughty as he approached the goal line, facing the end boards and looking in an upward stare. None of the Officials shared Doughtys perspective! The next visual connection with the puck that any of the officials possibly had was when it was tracking downward just prior to striking Jonathan Quick on the numbers and deflected directly into the net. Drew Doughty immediately appealed to referee Martell and provided the evidence he had witnessed. Doughtys information would have been communicated in the conference held at the Referee crease. The gut wrenching truth these guys wrestled with was that none of them had seen the puck strike the protective netting to rule the play dead. The Officials were helpless to do anything other than allow the goal to stand since the puck clearly enter the net off the back of Quick. With an understanding of what took place I cant fault the Officials one bit. The blame rests clearly on the current video review process and the Hockey Operations Department and personnel that make exclusive "officiating decisions" on a nightly basis in the Situation Room in Toronto. Kurt, you asked when is the NHL going to change things to expand video review for goals? I cant understand why the general managers have not insisted on revamping the review process. It is surely time for a complete overhaul! I point out Rule 38.4 (viii) which says, "The video review process shall be permitted to assist the referees in determining the legitimacy of all potential goals (e.g. to ensure they are "good hockey goals"). For example (but not limited to), pucks that enter the net by going though the net messing, pucks that enter the net from underneath the net frame, pucks that enter the net undetected by the referee, etc." I would hope that an undetected puck that leaves the playing surface (hitting protective netting out of play) and then directly results in the puck entering the net would fall under that broad "ETC" in the rule to permit video review to "assist the referees" in determining the legitimacy of the goal. This was well beyond the parameters of a "good hockey goal!" There was absolutely zero "assistance" provided from the Situation Room as the officials huddled on the ice in an attempt to make a correct determination. I suspect the officials were dying a thousand deaths on the ice and the replay clearly demonstrates that a telephone call was not initiated by the Toronto Situation Room to "assist the referees." Major League Baseball announced last Thursday (link) at the Owners Meetings their unanimous decision to fund and expand instant replay for the 2014 season. The key points for quick reference are including the managers challenge and most importantly that off-site decisions will be conducted at the Replay Command Center in New York which will become their Situation Room. Two additional four-man umpire crews will be hired and rotated through New York to review video feeds. The replay umpires decision in New York will be final. Take a lesson NHL; its time to make a positive change with regard to video review. Perhaps Los Angeles Kings general manager Dean Lombardi might agree. Зарегистрируйтесь, чтобы увидеть ссылку! .S.-Portugal game on June 22 in the Amazonian jungle city of Manaus. FIFPro, the international soccer players union, had pressed FIFA to avoid the earliest kickoffs in the hottest and most humid weather. Зарегистрируйтесь, чтобы увидеть ссылку! . The start of the seasons fifth and final major was delayed two hours due to heavy rain in the area. The tournament eventually began, but with water on the greens and the rain persisting, players were called back to the clubhouse less than an hour after the first group teed off. Зарегистрируйтесь, чтобы увидеть ссылку!. You can catch all of the action LIVE on TSN2 at 6pm et/3pm pt. The Heat reached that mark Saturday night when they ruined the Philadelphia 76ers home opener. Зарегистрируйтесь, чтобы увидеть ссылку! . They know how difficult it is to beat the San Antonio Spurs. George scored 28 points and Indiana defeated San Antonio 111-100 on Saturday night, snapping an 11-game skid against the Spurs. Зарегистрируйтесь, чтобы увидеть ссылку! .com) - The Los Angeles Dodgers made it official Tuesday and signed pitcher Brandon McCarthy to a four-year contract.MONTREAL -- If the fans had their wish, Caroline Wozniacki would be facing local favourite Eugenie Bouchard in the third round of the US$2.44 million womens Rogers Cup on Thursday. Instead, the former world No. 1 from Denmark will play Shelby Rogers, the American qualifier who put a quick end to Westmount, Que., native Bouchards homecoming tournament in the second round. Wozniacki breezed through a second match in a row with a 6-1, 6-2 win over Klara Koukalova on a side court on Wednesday. She has lost only five games in two matches so far at the hardcourt event. "Its my favourite surface," she said. "Ive been playing pretty well lately. "Montreal has always been a good place for me, winning here a few years ago (2010). Im feeling good and hopefully I can keep going." In the evening feature, world No. 1 Serena Williams dispatched Samantha Stosur 6-0, 6-2 in a match interrupted 28 minutes by a sprinkle of rain. Williams, the defending champion who is coming off a victory Sunday at Stanford, then surprised the centre court crowd by doing a courtside interview in French. Wozniacki is coming off her first win of the season at the Istanbul Cup, where she dropped only two games while beating Roberta Vinci in the final. Now ranked 13th, Wozniacki will face the world No. 113 in Rogers, who played the spoiler as Bouchard battled rust and her nerves on Tuesday night. "I know how she looks like, but I dont know much about her game," said Wozniacki. "I will definitely have my team tell me how she plays." It promises to be a quieter match than if it was Bouchard, who had the packed centre court solidly behind her, as well as her Genie Army fan group in from Australia. "I dont really care, to be honest," added Wozniacki. "Obviously, Rogers must have played really well to beat Genie. "With the whole crowd, as well, for Genie, you know it wasnt easy. But for me, its a new match. It doesnt matter whos on the other side." If she keeps winning, it may draw attention back to her tennis game and away from her famous split in May with golfer Rory McIlroy. Both players seem to be doing better since then, with McIlroy following his British Open title with a win at last weeks Bridgestone Invitational. "Ive moved on. I hope everyone else has moved on, too," said Wozniacki, who will be running the New York Marathon in November, when the wedding was to have been. Williams needed only 59 minutes of playing time to improve her career record against Stosur to 7-3.dddddddddddd Next she will face 15th-seeded Lucie Safarova, against whom she is 6-0. Safarova beat Magdalena Rybarikova 6-4, 6-2. "She is an interesting player," Williams said of Safarova. "Shes extremely tricky. "Weve had some tough matches. I know weve gone to three sets on occasions. Its definitely not an easy match for me." Williams has won the Rogers Cup three times when it is held on alternate years in Toronto, including last year, but she has not played in Montreal since she retired from the final with an injury in 2000. Odd, since shed be a natural favourite for the mostly French-speaking crowd. "Im really happy to be a part of the tournament this year. Its just really cool," she said. "Ive actually been studying French for most of my life, so yeah, I should be able to speak even better, to be honest. "I love it in Canada because I understand everything. Its a lot easier for me to speak. The accent is much easier for me to understand." In a centre court match, fourth-seeded Maria Sharapova survived a rough first set to down world No. 27 Garbine Muguruza of Venezuela 4-6, 6-3, 6-1. "I was happy that I was able to turn it around," said Sharapova. "I didnt feel good. "I made a lot of errors in the first set. When youre able to finish stronger than your start, thats always a positive because you give yourself an opportunity to keep playing in the tournament." Her next opponent is 14th seeded Carla Suarez Navarro, who got past lucky loser Karolina Pliskova 6-1, 3-6, 6-3. British qualifier Heather Watson upset 10th-seeded Dominika Cibulkova 6-2, 6-7 (3), 7-6 (5). Watson let a 5-2 lead slip away in the third set before rallying for the victory. The 22-year-old will face eighth-seeded Victoria Azarenka in the third round on Thursday. Watson won two qualifying matches on the weekend before downing Tereza Smitkova in the first round. Cibulkova was coming off a first-round win over 17-year-old Francoise Abanda of Montreal. Angelique Kerber, the sixth seed, ousted Caroline Garcia 6-4, 6-1. The two faced one another in Madrid in May, with Garcia winning when Kerber retired in the second set with a back injury. Second seed Petra Kvitova downed Casey Dellacqua 6-3, 6-2 and American qualifier Coco Vandeweghe upset ninth seed Ana Ivanovic 6-7 (7), 7-6 (7), 6-4 in the late matches. In doubles, Muguruza and Saurez Navarro beat Abanda and Stephanie Dubois of Laval, Que., 6-3, 6-4. ' ' '
