| Hot Rolled Material 5182 Aluminum Coil Sheet for Closure Caps Pulling Rings Pull Tab We can produce the aluminum coil for pull tabs or easy open ends, which is normally used in can lid. The specification of aluminum sheet for aluminum easy open ends : 1)width and length:to cut as per your requirement 2)thickness: 0.3mm 3)alloy:5182 4)temper:H18 5)packaging detail: export standard seaworthy wooden pallets. 6)Tensile Strength:350~400MPa 7)Elongation:≥6% 8)There are no stop marks or pinch marks on the surface of aluminum sheets. 9)There are no water stains or blisters on the surface. 10)The surface of aluminum sheets is very clean without lots of impurities. 11)It's the best material for aluminum easy open ends. 12) lead time: about 30 days. 13)MOQ: about 5MT for each size. We can also produce the aluminum alloy 1100, 1070, 3105, 5052, 8011 alloy for the caps, if you have any needs, please feel free to contact me or email me. Welcome.Alu for Caps Material 5182 products website:http://www.aluminum-producer.com/aluminum-for-caps-material/aluminum-for-caps-material-5182/ |
Сообщение astao226 » 06 янв 2020, 05:43
