Edmontons next two
jinshuiqian0713
Edmontons next two
Сообщение jinshuiqian0713 » 05 мар 2020, 04:48
Madison, WI (SportsNetwork.com) - Frank Kaminsky returned to the lineup from a concussion and helped No. 7 Wisconsin shake off Sundays loss to Rutgers with a 70-55 win over the Nebraska Cornhuskers. Kaminsky led the Badgers (16-2, 4-1 Big Ten) with 22 points and moved over 1,000 career points in the process. Wisconsin got 13 points and seven rebounds from Nigel Hayes, and Sam Dekker and Bronson Koenig each chipped in 11. Koenig was in the starting lineup after Traevon Jackson broke his foot in Sundays setback. Nebraska (10-7, 2-3) was led by Terran Petteway with 27 points but only seven of those came in the second half. Shavon Shields, averaging 17.1 points per game, only scored eight. The Cornhuskers scored nine of the first 12 points in the second half to pull within four. Walter Pitchford scored five of those points, but that was as close as the game got before Wisconsin pulled away. A 13-0 Badgers run was highlighted by Duje Dukans four-point play and extended their lead to 17 points. Dekker scored seven of those points and capped the spurt with a 3. Shields pair of free throws ended the run but did not end the Huskers drought from the field. After Pitchfords dunk that cut their deficit to 40-36, it took seven minutes before Petteways jumper ended the streak of eight consecutive misses. Nebraska made five of its last nine shots and closed the game with a 7-0 run against Wisconsins reserves to trim the Badgers game-high lead of 22 points. In his first action back on the court, Kaminsky scored 15 points in a balanced first half for Wisconsin. The Badgers shot 15-of-24 from the field and closed the half on a 9-0 run to take a 37-27 lead into the break. The Huskers did not have the same balanced attack. Petteway scored 20 first- half points on 8-of-13 shooting, including four 3s, while the rest of the team combined to shoot 3-of-14. Petteway scored the final 10 points of the half for Nebraska. Game Notes Dukan scored all 10 of Wisconsins bench points ... The Badgers improved to 5-1 against Nebraska since the Cornhuskers joined the Big Ten ... Wisconsin improved to 13-0 when allowing fewer than 60 points ... Jackson is expected to miss most of the remaining regular season with his injury ... Each team takes the court next on Tuesday when Wisconsin hosts Iowa and Nebraska takes on Minnesota. Зарегистрируйтесь, чтобы увидеть ссылку! . Hall had a goal and three assists in a 5-4 loss to San Jose on Tuesday, had an assist in each of Edmontons next two games the capped the week with a goal and two assists in the Oilers 4-2 win over Anaheim on Sunday. Зарегистрируйтесь, чтобы увидеть ссылку! . Mauer struck out to end the inning, with a runner on third base in the seventh on Wednesday and the Twins trailing 1-0. Everybody does this, of course, in a sport with a 30 per cent success rate at the plate long proven to be a benchmark of excellence. Зарегистрируйтесь, чтобы увидеть ссылку!. - After spending the morning in the hospital, Logan Couture gave the San Jose Sharks the spark they needed. Зарегистрируйтесь, чтобы увидеть ссылку! . -- Antoine Bibeau bought the Val-dOr Foreurs valuable time at the Memorial Cup with his 51-save shutout Friday. Зарегистрируйтесь, чтобы увидеть ссылку! . -- Pinch-runner Rajai Daviss decision to steal third base just as Oakland catcher Derek Norris was throwing the ball back to the pitcher caught most everyone by surprise -- including several of his Detroit teammates.MONTPELLIER, France -- French wild-card entry Paul-Henri Mathieu reached the second round of the Open Sud de France when compatriot Nicolas Mahut retired while trailing 6-1, 3-0 on Monday. Ranked 140th in the world, Mathieu earned his first victory in the main draw of a tourrnament this year to set up a meeting with top-seeded Richard Gasquet.dddddddddddd Mathieu saved a break point in the opening game and went on to win five straight games for a 5-0 lead. Mahut made four double faults and won only nine of his 28 service points. ' ' '
