DESCRIPTION OF 3105 ALUMINUM SHEET:
3105 aluminum sheet belongs to AL-Mn alloy with 98% pure aluminum and slight alloy addions for strength,also call it anti-rust aluminum sheet with Mnganese additions and it has excellent anti-rust property. The strength is higher 10% more than alloy 1100,so the formability,welding,corrosion resistance are good.Mainly used for components and parts which required higher strength than alloy series 1,such as cooking utensil,food,chemical treatment,storage device,pot,groove,pressure vessel,pipeline,heat sink,ships and so on.
CHEMICAL COMPOSITION OF 3105 ALUMINUM SHEET:
ElementsSiFeCuMnMgCrZnTiOthersAl
Contents0.60.70.30.3-0.80.2-0.80.20.40.10.15Remain
PACKAGING SHOW:
1: Wooden pallets with waterproof paper and brown paper,
2: Drying agent as required and plastic paper,
3: Plywood on the bottom and top of pallets,
4: Wrapped by galvanized steel strip,
5: Hard board on the anodized steel fasten point,
6 : Or can be customized as buyers’ requirements.
FAQ:
Q1: What’s the MOQ for order
A1: 5 tons for each size.
Q2: How can I get cargo?
A2: Ship based on sea
Q3: How is the trial order?
A3: It’s available with 5tons or depends on required
Q4: We are new in this field.
A4:Nothing to worry about,we will teach you everything well.
Q5:Why Xiangxin?
A5:Competitive price,guarantee quality,timely delivery,good after-sales service.Aluminium Sheet factory
website:http://www.xiangxin-alu.com/aluminium-sheet/
wszj222333
Вернуться в «Форум жителей ЖК - «Квартал 38А»»
