CNC Precision Machining
cnkene
Сообщение cnkene » 26 фев 2020, 05:37
1. Product Description and capabilities for CNC Milling aluminum parts
Applicable MaterialMetal: Aluminium, Steel, Stainless steel, Brass opper, Bronze
Plastic: ABS, Acrylic, Nylon
Working ProcessMachines: 3 4 5 -axis Machining centers; CNC   turning centers and lathe milling ; Auto lathe machines ,Stamping machines;   Injection molding machines.
Tapping machines; Cutting machines; Polishing machines
Surface Finish1.As Machined
2.Sand Blasting
3.Powder Coating
4.Smooth Finish
5.Anodizing
6.Chrome Plating
7.Gloss or Matt Color
8.And Many More Custom Coatings & Finishes
High Tolerance0.005-0.01mm
Inspection100% inspection before shipping
PackingInner-Plastic Bag; Outer -Standard Carton Box.
Payment Terms30 -50%T/T in advance, the balance before delivery;   PayPal or Western Union is acceptable
Shipment Terms1) 0-100kg: express&air freight priority,
 2) >100kg: sea freight priority,
 3) As per customized specifications
Trade termsEXW, FOB, CIF,CFR
Drawing formatJPEG,PDF,DWG,DXF,IGS,STEP.CAD
Applicationsauto,motorcycle,industry,ariculture,mine,furniture,elevator,etc
Machining equipmentCNC milling&turning machine, stamping machine   ,milling machine, grinder machine ,
 drilling machine, and optical comparator etc;
File FormatSolidworks,Pro/Engineer,Auto CAD,PDF,JPG
NoteThe products shown here is only to present the   scope of our business activities.
 We can manufacture custom parts according to your drawings or samples.
Workshops to produce CNC Milling aluminum parts.
Quality control is most important to ensure the parts to meet our customers’ requirement.
QUALITY CONTROL PROCESS :
1) Checking the raw material after they reach our factory------- Incoming quality control ( IQC)
2) Checking the details before the production line operated
3) Have full inspection and routing inspection during mass production---In process quality control (IPQC)
4) Checking the goods after they are finished---- Final quality control (FQC)
5) Checking the goods after they are finished-----Outgoing quality control (OQC)
We are carrying 100% inspection with professional testing tools and equipment. Please don’t worry.
The products presents here is only for reference, we make Horizontal CNC Milling and Vertical CNC Milling components as per customer drawings and samples can be provided for testing if we agree on the price terms.
Our Engineer can evaluate the product cost based on the design and technology adopted.
2. Quotation details required
please kindly provide information as below for us to quote:
1). Size drawing
2). Material
3). Quantity
4). Surface treatment(Polishing; Anodize; Nickel, Zinc, Tin, chrome, Silver plating etc.)
5). Tolerance
6). PackingCNC Precision Machining
website:http://www.sytechmachining.com/cnc-fabrication/
Вернуться в «Форум жителей ЖК - «Садовые кварталы»»
