Feature:
A dedicated metering pump for CO2: It has patent low-temperature pump head and packing, and the unique sealing design ensures no leakage.
The quick-opening system of Extraction Kettle: It can open extraction kettle after CO2 emission. The sealing material can repeated use because of no swelling, it can save the refueling time and Improving the efficiency of the equipment.
Its’ entrance is equipped with auxiliary agent, it can make extraction material and CO2 separation completely by adding different adjuvant with the dryer and the purifier.
It can add chromatographic analysis and configure data collection systems in temperature, pressure, flow, and so on according to the customer’s requirements
It can configure heating or cooling third separation kettle to increase the diversity of the extraction and separation.
It has the function of recycling CO2 to increase the gas utilization. All heating and cooling components configure heat preservation measures to achieve energy conservation and environmental protection.
Technical parameters:
ModelThe extraction kettle volumeThe number of extractive kettleThe number of separate kettlePressure classesCombination functionNote
DPMCLJ0.1×1-2/50100ML1250MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ0.3×1-2/50300ML3350MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ0.5×1-2/5050ML1250MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ1.0×1-2/501L1250MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ1.0×2-2/501L2250MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ5.0×1-2/505L1250MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ5.0×2-2/505L2250MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ10.0×2-2/5010L2350MPaConfigure distillation columnCan combine according to the customer’s requirements
DPMCLJ25.0×2-2/5025L2250MPaConfigure distillation columnCan combine according to the customer’s requirementsSupercritical Extraction System suppliers
website:http://www.depamupumps.com/supercritical-extraction-system-1
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 5 гостей
